decinding on tires (lift or no lift)help!!!
  • 1943 Views
Offline sidekick101
  • 128
  • best site on the net
« on: January 14, 2007, 07:58:31 PM »
lookin at tires and deciding hmm. 2 questions. 235 fit stock. should i just get the 235s or do the budget lift for for 31's? any 31's that are great?  http://www.1010tires.com/tire.asp?tirebrand=Firestone&tiremodel=Destination+M%2FT i kinda like the looks of these and they got a good customer rarting. any input would be great
1993 sidekick JX, 2 dr, soft top, automatic,
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: decinding on tires (lift or no lift)help!!!
« Reply #1 on: January 15, 2007, 11:47:17 AM »
I would definitley recommend going with the budget lift and running 31's as a minimum. I've been running mine this way since last spring and it's great, now I want to go bigger. I drive 120kms a day round trip and off road on the weekend.
I run the trexus MT's and I like them a lot. With some weight in the back they are fine in the snow as well. here's a link
http://www.intercotire.com/site35.phpk.
 Price these out before buying the firestones, they are almost the same price, at least they were around my place at most places and these tires are great!
Regards
Jim
Offline bzzr2
  • 1011
« Reply #2 on: January 15, 2007, 11:50:45 AM »
even if you go halfway in the middle, to just the suspension or just the body lift you can fit 30's under there!
09 taco reg cab short box 4x4
Offline sidekick101
  • 128
« Reply #3 on: January 15, 2007, 07:34:57 PM »
yea true true i dunno whta i was thinking lol. why do all thta work to keep 235 duhh. anway i think i found a new love for tires thanx  Jimiweld. think with that budget lift i could get bigger or not reccomended? and you say you have done the budget lift? how hard was it for you? and u running a 2door or 4?
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #4 on: January 16, 2007, 04:21:14 AM »
I'm running a 2 door and the lift wasn't too bad, I've done my friends as well since then. I did use Sky's 1.5" coil spacers and strut extensions instead of the jeep ones as mentioned but either way is fine I'm sure. I didn't want too much stress on the CV's.
  Have a welder handy to extend the shifters and possibly the steering shaft. I think the hardest part for me was getting all the bumpers off and trim around the headlights, everything up here gets rusted pretty good with the salt on the roads in the winter. The lift itself was straight forward. I would recommend doing it yourself if you can, that way you'll know it was done properly and you'll get to know your rig much better. Everyone here will help along if you have any snags. Plan for a full days work your first time doing it, nothing ever goes as smoothly as planned.
  With just the budget lift true 31" tires is all you can really run. I've also now cut all my wheel wells back because I'd like to go bigger soon, I may do the SAS but still haven't decided really. I also have the rocker guards in (cut out the rockers and welded in square tube) per Diggers instructions on the site here.
  You'll be very happy with the 31" tires and the budget lift, I think it's the most bang for your buck and it runs good on the trails.
