Widening without welding washer
TysonS
383
www.funinbc.com
January 14, 2007, 11:08:58 PM »
i need to do the hagen widening mod but i don't have a welder, i can get the sub cut to run the drivers cv but is it ok to not weld the washer onto the frame like in this pic
http://www.zukiworld.com/forum/index.php?action=dlattach;topic=9229.0;attach=1030
thanks
2 Dr. 91' 8v Sidekick| 3" Body Lift | 4" Gas Tank Lift | 3.5" Suspension Lift | Snorkel | Custom Bumpers | Sliders | 31" LTB's | Detroit | 4.24 Tcase | TT front locker soon
FNG
197
91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
Re: Widening without welding washer
January 15, 2007, 05:18:51 AM »
No,if you do not weld in the washer it may allow the cross member to tear back into the old hole.
TysonS
383
www.funinbc.com
January 15, 2007, 05:21:13 PM »
so are you saying that i should just build it all put a washer on there but not weld it, throw it all back together, trailor it down to my welder buddy and get him to crawl under and weld it to the x member?
crikeymike
713
Local to Western Washington?? Visit WAZUKS.com
Reply #3 on:
January 15, 2007, 08:15:58 PM »
That sounds right to me. Put it all together the way they say, then take it to someone and have them weld it, but make sure it is at the right alignment (the bolt i mean) before they weld it in place.
1993 4-door Sidekick
4.24:1 t-case
WAZUKS member - visit
http://www.wazuks.com
TysonS
383
www.funinbc.com
Reply #4 on:
January 15, 2007, 10:56:29 PM »
sounds good, probably won't do this till spring, too cold
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #5 on:
January 16, 2007, 04:38:36 AM »
Use good thick washers. MarkyB had problems with the stock mountings points elongating.
http://www.rhinopower.org
