unknown problem need help!!!
  • 9 Replies
  • 2450 Views
Offline jaybyrd92
  • 30
  • 1992 Suzuki Samurai JL
« on: January 16, 2007, 04:58:21 PM »
My '92 JL would not go into gear this morning when I first statred up. I had the clutch pedal to the floor but I could not get it into gear. After I let it idle for a few minutes and warm up it worked fine.
 Is the clutch the problem? Or is it something else?
 A buddy of mine said there was a bushing in the transfer case , that would cause this to happen when it wears out. Any Ideas?
Never use money to measure wealth.
Offline ROSS
  • 1412
Re: unknown problem need help!!!
« Reply #1 on: January 16, 2007, 05:58:30 PM »
the shifter sheet in the t-case won't stop you from shifting the tranny.
Offline jaybyrd92
  • 30
« Reply #2 on: January 16, 2007, 07:48:25 PM »
So, Do you think it is the clutch?
                                                Thanks
Offline ROSS
  • 1412
« Reply #3 on: January 16, 2007, 07:52:14 PM »
that's where to start. check the cable. was it wet and froze?
Offline jaybyrd92
  • 30
« Reply #4 on: January 17, 2007, 06:08:52 AM »
It shouldn't have been. It hadn't rained that day, and I keep it inside my garage.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #5 on: January 17, 2007, 12:51:53 PM »
I suspect water in the upper shifter compartment on top of the tranny. Deep water crossings cause it to build up in the separate shifter linkage compartment, then it freezes causing shifting trouble until it warms up...
Offline jaybyrd92
  • 30
« Reply #6 on: January 17, 2007, 04:29:01 PM »
AAAAHHH! That makes sense I will check that too. Thanks alot!!
« Reply #7 on: January 18, 2007, 04:55:25 AM »
Its that time of year again!
sapien
« Reply #8 on: January 19, 2007, 10:42:08 PM »
try changing the tranny oil.  if it has regular GL5 gear oil in it instead of GL4 manual trans fluid then it will be significantly harder to shift in cold temperatures
my choice would be Redline Synthetic MT-90
Offline jaybyrd92
  • 30
« Reply #9 on: January 21, 2007, 02:55:03 PM »
I have already changed the tranny oil. I used Royal Purple synthetic. seems to work very well.
Thanks alot for the suggestion though.
I have narrowed down the problem to the clutch cable itself, still working on it though.
