RPO code Reader
  • 4326 Views
Offline 99Trackerconv
  • 430
  • I love my Tracker
RPO code Reader
« on: January 19, 2007, 06:52:33 PM »
It will work for Chevy Trackers 99+ but I'm not sure if it will work for Geo's or Suzuki's
I guess if you have the RPO sticker in your glovebox it should work.
http://www.s10forum.com/rpo/index.php
                           Here are my specs!!!
AK5   RESTRAINT SYSTEM , "SEAT, INFLATABLE, DRIVER & PASS"
AM7   SEAT RR , FOLDING
AN4   RESTRAINT PROVISIONS , CHILD
AR9   SEAT , "FRT BKT, DELUXE"
BNN   COMPARTMENT , "STOWAGE, CARGO AREA"
B1A   PORT OF ENTRY , CAMI
B58   COVERING , "FLOOR MAT, FRT & RR, CARPETED INSERT"
B84   MOLDING B/S , EXTERIOR
C60   HVAC SYSTEM , "AIR CONDITIONER FRT, MAN CONTROLS"
DL5   DECAL , ROADSIDE SERVICE INFORMATION
DR1   MIRROR O/S , "LH & RH, MANUAL CONTROL, COLOR"
FE9   CERTIFICATION , "EMISSION, FEDERAL"
HC1   AXLE REAR , 4.62 RATIO
J41   BRAKE SYSTEM , "PWR, FRT DISC, RR DRUM, CAST IRON"
K34   CRUISE CONTROL , "AUTOMATIC, ELECTRONIC"
L34   ENGINE , "GAS, 4 CYL, 2.0L, MFI, DOHC"
MM5   MERCHANDISED TRANS , MAN 5 SPD PROVISIONS
M59   TRANSMISSION , "MAN 5 SPD, SUZUKI, 3.65 1ST, 0.795 5TH"
NF2   EMISSION SYSTEM , "FEDERAL, TIER 1"
N33   STEERING COLUMN , TILT TYPE
N40   STEERING , "POWER,"
PG2   WHEEL , "15 X 5.5, STEEL"
P17   COVER SPARE , WHEEL
QCE   TIRE ALL , P205/75R15/N BL R/PE ST TL ALS
T61   LAMP SYSTEM , DAYTIME RUNNING
T82   HEADLAMPS CONTROL , AUTOMATIC ON-OFF
UH8   CLUSTER , "INST, COOL TEMP, TRIP ODOM, TACH"
UL0   RADIO , "AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH"
UQ0   SPEAKER SYSTEM , "4, DUAL FRT DR MTD, DUAL STD RGE QTR/SHELF"
U73   ANTENNA , "FIXED, RADIO"
ZU1   PACKAGE , "PICK-UP BOX DELUXE""" <---- what?
ZY1   COLOR COMBINATION , SOLID
1SB   PACKAGE , OPTION 02
17D   TRIM COMBINATION , "CLOTH, MED GRAY (97) (D)"
41T   TOP COLOR , BLACK (96)
89U   PRIMARY COLOR , "EXTERIOR, DK MULBERRY MET (02)" <---- Thats the wrong color.. Mine is Purple Graphite Met
Whats yours?
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: RPO code Reader
« Reply #1 on: January 19, 2007, 07:12:06 PM »
It should work for Geo's, all three of mine have had the glovebox RPO sticker.  Neither of my Suzukis has a GM RPO sticker.  Doubt their influence spread that far into the Suzuki world.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: RPO code Reader
« Reply #2 on: January 20, 2007, 11:53:36 AM »
Seems right.
AU0   "LOCK CONTROL, ENTRY" , REMOTE ENTRY
AU3   LOCK CONTROL , "SIDE DR, ELEC"
A31   WINDOW , "POWER OPERATED, ALL DOORS"
DG7   MIRROR O/S , "LH & RH, REMOTE CONTROL, ELECTRIC, COLOR"
NF7   EMISSION SYSTEM , "FEDERAL, NLEV"
NG5   REGISTRATION , "EMISSION, CERTIFICATION, FIFTY STATE (50)"
NV5   SHIELD , DIFFERENTIAL CARRIER
NX2   WHEEL SPARE , 15 X 6.0 ALUMINUM
NY7   SHIELD , TRANSFER CASE
N29   WHEEL , "15 X 6, ALUMINUM, SPECIAL"
QCM   TIRE ALL , P215/75R15-100S WOL R/PE ST TL ALS
TZ2   EVAPORATIVE SYSTEM , ON BOARD REFUELLING VAPOR RECOVERY
U1C   RADIO , "AM/FM STEREO, SEEK/SCAN, CD, CLOCK, ETR"
VM5   LABEL INFORMATION , "CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT"
ZR2   CHASSIS PACKAGE , "HIGH WIDER PERFORMANCE, 4 X 4 SPORT"
ZV1   STATEMENT OF ORIGIN , MANUFACTURE
Z05   CONVENIENCE PKG , #
1SC   PACKAGE , OPTION 03
17G   TRIM COMBINATION , "CLOTH, MED GRAY (97) (G)"
17I   INTERIOR TRIM , MED GRAY (I) (97)
17I   INTERIOR TRIM , PEWTER (99) HOLDEN
19U   PRIMARY COLOR , "EXTERIOR, JET BLACK (05)"
5A0   GRILLE , "BLACK, GLOSS"
XL-7 front coils
1.5" rear coil spacers
