will this be good??
  • 2673 Views
Offline museboy07
  • 641
will this be good??
« on: January 21, 2007, 07:45:35 PM »
hey everyone i am on a strict budget seeing that im only 17 yrs old but i love to 4 wheel my 94 track..i want to get a lift and some mud tires.  Im thinkin bout gettin 235 75 15 mud tires for dirt cheap and i wanted to get a set of 1 1/2 inch coil spacers from digger and the 2 inch body lift from RRO.  will this look and perform good.  Im goin wit the 235s cause bigger ones are just too much $ for me to afford and i was lookin around and i found that 235 75 15 tires are just a tiny bit smaller than 30 inch tires..is that true cause the tires i want are like 50 more bucks for 30 inch..just tell me wat you guys think..thanks
« Last Edit: January 21, 2007, 08:23:30 PM by museboy07 »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: will this be good??
« Reply #1 on: January 21, 2007, 08:41:16 PM »
Sounds to me like you're working a good plan.  You can start with the 235/75 tires, they'll just clean off a little spot on the frame at full lock, even without the body lift.
30s are too big without putting more work/$ into it.  Stay as close to 29" as you can.
« Last Edit: January 21, 2007, 08:44:24 PM by beercheck »
XL-7 front coils
1.5" rear coil spacers
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: January 21, 2007, 08:49:17 PM »
Hey, I'm 17 too. Right on! I have a 1.5" lift and 235/75R15 tires on my 4 door 97 and I think if you are going to put on the 1.5" lift and a 2" body lift, you should go for the bigger meats. Even with no body lift, I wish I had gone for a bit bigger than 235/75R15 (28.8 according to some online tire size converter) because it looks like I've got fairly good tire-to-fender clearance. Here's some pics to help out:
I would go for 30" tires if you do the body lift with the 1.5" coil spacers.
PS my 235's don't rub at all. That's why I decided on them instead of 30"...figured 30" would be just too much for 1.5" lift and I didn't want to trim at all.
« Last Edit: January 21, 2007, 08:52:14 PM by olija »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: January 21, 2007, 08:55:28 PM »
Looks nice!
If money's an issue, though, do the same and go 29s (235/75).  Regretting that last inch isn't worth not having gas money to go wheeling.
XL-7 front coils
Offline museboy07
  • 641
« Reply #4 on: January 21, 2007, 09:48:17 PM »
thanks for the replies guys i think im gonna go with the coil and body lift wit the 235s. it might not sound good to some ppl but it should perform well.  also i found these tires they look good and for the price i might not be able to pass them up
http://www.prostreetonline.com/merit_all_country_mt_tires.html
Offline kirknd4spd
  • 333
« Reply #5 on: January 21, 2007, 10:08:21 PM »
personally, i wouldnt get the body lift until youre ready for bigger tires. that just seems like a lot of lift just for 235's.
Offline ZeusZuki
  • 411
« Reply #6 on: January 21, 2007, 10:10:11 PM »
Hi museboy7  :)
From my own personal experience I have found that you can get away with a surprisingly small tyre and really go places. The IFS of the Kicks give very good clearance with a relatively small lift, the rear is another kettle of fish though - the bigger the rubber out back the more air under your pumpkin  :-\
Your plan is sound. You will not run into gearing issues with your decision, the drive train will take a thrashing all day and get home alive  ;D .
My advice: Go for it and when you go wheeling think about the terrain ahead and take good lines. You do not have to conquer everything you come across to wheel - the best wheelers out there are the ones who tale good lines and preserve their rigs and this my freind is what you should aim for  >:D .
Good luck and hap hap happy  ;D  ;D  ;D wheeling.
ZeusZuki  8)
Offline museboy07
  • 641
« Reply #7 on: January 21, 2007, 11:09:14 PM »
thanks everyone.  ppl sure are helpful on this forum  :)
Offline bubba2243
  • 90
« Reply #8 on: January 22, 2007, 04:29:08 AM »
will you be on the road much if not try a  set of 29 swamper and they are great off road
it aint the size of the dog in the fight but the size of the fight in the dog
