Will this work as cheapo susp. lift?
  • 3454 Views
Offline museboy07
  • 641
« on: January 23, 2007, 04:08:26 PM »
I got a 94 track and ive been searchin around and i think i came up wit a cheap 2-3 in suspension lift.
Needed parts:
2 crown vic shocks for rear- $30 (cheap monroe's from parts store)
4 2 inch jeep tj coil spacers (need slightly modified) $80
flip front strut mounts over (requires 6 new bolts) $10
thats only $110!!...tell me what you guys think bout this
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Will this work as cheapo susp. lift?
« Reply #1 on: January 23, 2007, 04:22:20 PM »
Don't forget to budget in a front-end alignment if you don't want to buy another set of tires really soon.
XL-7 front coils
1.5" rear coil spacers
« Reply #2 on: January 23, 2007, 05:06:56 PM »
  Lots of zuks running that set up, except usually stay less than 2" on spacers in front.  And you can pick up coil spacers made for Trackers for the same or less than the TJ spacers and you won't have to modify them.  You may also have to adjust the camber when you have it aligned.  You can do that either with camber bolts (another $20) or I've heard you can modify the strut slots (?) yourself.
Offline museboy07
  • 641
« Reply #3 on: January 23, 2007, 05:57:45 PM »
ok then here we go..
Needed parts:
4 1 1/2 inch sky's off road coil spacers-$90...with shipping
flip front strut mounts over (requires 6 new bolts)- $10
alignment-roughly $45-$50
camber bolts- $26...with shipping
http://www.ultrarev.com/cart.php
Thats still only $206 for alot better setup then stock
I also wanted to find out how much height will 1 1/12 inch spacers give to your rig...is it 1 1/12 inches or is it different??
Offline 2K-Otic
  • 16
« Reply #4 on: January 23, 2007, 08:28:51 PM »
That's pretty much the standard cheap way of lifting Track/kicks. It's how I did mine.
92 Tracker: 2" home made coil spacers (1.5" in front), 3" home made body lift, some camber bolts from the local parts store, strut mount flip, and crown vic shocks, 15x8 wheels with 2.5" back spacing mounted with 31x10.5 Mud King tires.
Had to do a little trimming of the front fenders to be able to turn lock to lock. The whole set up works pretty well for such a low cost. I had to replace my front struts and I still only have about $250 in the whole lift (if that).
1.5" spacers will give you approximately 2.25" of lift in the front, and a straight 1.5" of lift in the rear. The front is different due to the placement of the springs on the A-arms. The springs are obviously inboard of the ball joint and wheel,etc. Due to the fact that the A-arm has a fixed pivot point it scribes an arc as moves up and down. If you put a 1.5" spacer on the spring it is going to move the end of the arm farther down. The ratio that i was told to go by when I was researching my build was 1.5 times the length of your front spacer = approx. amount of actual lift. Thus 1.5"x1.5=2.25" or 1.75"x1.5=2.63", and so on.
Hope this helps you out...btw I'll try to keep you posted as to when I might be taking orders for spacers. And here's an attached pic of my tracker to give you some idea of what you can do for almost nothing. Note that the fenders were not yet cut in this pic.
92 Tracker
     2" Home made coil spring spacers
     3" Home made body lift
     3" Cold air intake
     31x10.5 Mud Kings on 15x8 spoke wheels
Offline PHX96TRACK
  • 90
« Reply #5 on: January 23, 2007, 08:37:18 PM »
It also looks like you can elongate or drill a new mounting hole in your struts to avoid camber correction, alignments, bolts as LilRed mentioned. I'm still checking this out, if someone would put it out there in a thread I'd be much olbliged  ;D  All of the stuff I've read is kind of sketchy between this board and the other one.
« Last Edit: January 23, 2007, 08:39:38 PM by PHX96TRACK »
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: January 24, 2007, 05:33:05 AM »
http://www.zukiworld.com/forum/index.php?topic=13859.0
About 2/3's down the entire page, it's in the second post.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #7 on: January 24, 2007, 10:57:12 PM »
I elongated my upper strut holes as opposed to using camber bolts.  Cranked the bolts down tight and alignment hasn't changed in over a year now.
1993 4-door Sidekick
4.24:1 t-case
