Another newbie/wheel spacers
  • 11 Replies
  • 3992 Views
Offline Grizzqc
  • 24
« on: January 27, 2007, 05:17:13 AM »
Good day all .New guy here have 94 tracker and was wondering on what kind of wheel spacers to get?Of course this is just the beginging ;D
Re: Another newbie/wheel spacers
« Reply #1 on: January 27, 2007, 05:23:53 AM »
Hey Newbie! Welcome to the forum. You might want to start by trying the search function about your topic. I'm sure you will find many threads regarding this. Good Luck!
Offline 2K-Otic
  • 16
« Reply #2 on: January 27, 2007, 07:03:03 AM »
You're looking for wheel spacers for added width, right? Not coil spring spacers for extra lift?
For wheel spacers check out Spidertrax.
http://www.spidertrax.com/
92 Tracker
     2" Home made coil spring spacers
     3" Home made body lift
     3" Cold air intake
     31x10.5 Mud Kings on 15x8 spoke wheels
« Reply #3 on: January 27, 2007, 07:26:25 AM »
First off I'd like to Welcome you aboard Grizzqc
Why don't you start off by telling us,
what are you driving (or going to)
what you are looking to do with it.
that will help narrow down answersto insure you get the proper info you would like.
We wouldn't want to steer you in the wrong direction.
We also have a nice search option to speed up Q&As
Offline Grizzqc
  • 24
« Reply #4 on: January 27, 2007, 12:52:31 PM »
Hey guys thanks for the greetings.I am getting a 94 tracker 3" body lift I am not sure on the suspension how much of a lift but it is lifted >:D.I want to play in the mud with it and trail ride >:DHow big can I go with the tires with out creating to much breakage?And what type of tires will fit my need more mud than trails but it will be on the road to get to the trails 20-30 miles of black top.I believe it has a 1.6liter engine 5spd 2 door silver As soon as I get it home I will post pictures and more details and of course more questions .I am comm ing over from ATV'S to toy trucks
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #5 on: January 27, 2007, 01:52:32 PM »
well, if it has a 3" bodylift and maybe add some 1.5" coil spacers you could run 31's
I think the biggest tire the sidekick driveline can take is a 32"-33" tire, but that is just my opinion.
I would recomend the 31x11.50x15 Super Swamper LTB's  I'm running them and they were cheaper then a BFG mud and perform 100% better then the BFG muds IMO
Offline Grizzqc
  • 24
« Reply #6 on: January 27, 2007, 03:21:09 PM »
Oh WHAT IF i WERE TO GET NEW RIMS INSTEAD OF SPACERS WHAT SIZE RIMS WOULD i BE LOOKING FOR ??? SO I COULD HAVE A NICE WIDE STANCE
« Last Edit: January 27, 2007, 03:28:15 PM by Grizzqc »
« Reply #7 on: January 27, 2007, 04:15:45 PM »
You can either just go with a set of 15x8 with the standard off-set of 3 3/4"inch
or go with the Black RockCrawlers with a 2 3/4"inch offset.
I run both of these off-sets on mine.
Check out the first posting here on
Members Rides Info thread
and see what others are running for lifts/tires/wheels
Both of these have Calmini's 6"inch lifts
Heres15x8 with 2 3/4"inch off-set and 32x10.50 tires
Will need fenderFlares In most States
15x7s with 3 1/2"inch offset and 31x1.50 tires
15x8 with 3 3/4 off-set and 31x10.50 tires
And another pic of 15x8 with 2 3/4"inch off-set and 32x11.50 tires
Does this help explain anything?
« Last Edit: January 27, 2007, 04:24:32 PM by HotRod »
Offline 2K-Otic
  • 16
« Reply #8 on: January 27, 2007, 10:02:19 PM »
If you you're looking for wheels, be sure to check out www.summitracing.com. They have very competive prices, and they only charge a one time handling fee of $9.95...free shipping otherwise. They do charge shipping on tires but not on just wheels.
I got a set of US Wheel white 8 spoke wagon wheels from them. I went with a 15x8 with 2.5" backspacing (part #USW-70-5855R, cost per wheel - $33.88). They are mounted with 31x10.5 Mud King tires. This setup gives a very nice aggressive wide stance. I did have to do some cutting and trimming of the front fender opening. I also had to hammer the pinch weld on the inner fender flat in order to turn lock to lock with out rubbing. They do stick out beyond the fender wells and will require some flares eventually.
92 Tracker
     3" Cold air intake
Offline Grizzqc
  • 24
« Reply #9 on: January 28, 2007, 05:11:25 AM »
unfourtunatly Iam in montreal canada so shipping costs alot more than 9.99 :( I will have a look at those for sure though
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #10 on: January 28, 2007, 09:02:04 AM »
look into masterkit1.com for lift parts, there based in eastern canada somewhere
Offline Grizzqc
  • 24
« Reply #11 on: January 29, 2007, 01:22:05 PM »
Thanks for the info and pictures I think I am going to go with 31" LTB's they should be plenty to go and have fun with with minumuim damage >:D.Keep the info coming .Its so cold up here right now I am not even thinking off going to pick up the new toy yet :'(
