removing door pannels
  • 1510 Views
Offline cgreen84
  • 33
  • 1998 suzuki x-90, 5spd, 1.6L
« on: February 05, 2007, 05:09:55 AM »
trying to install new speakers in the doors but i dont want to break the pannels getting them off, any hints? problems u ran into?
drive it like you stole it
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: removing door pannels
« Reply #1 on: February 05, 2007, 12:08:43 PM »
I know the panels are pretty fragile, so I wouldn't recomend doing it when the panels are cold or they will likely break easily. With the panels warm use a trim panel fork and gently work your way around the sides and bottom of the panel. Don't be in a hurry or you will probably break something.
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: February 05, 2007, 10:05:43 PM »
Start at the bottom, there are some little recessed areas you can stick your fingers under if I remember correctly.
