slopy steering
  • 9 Replies
  • 2608 Views
Offline ADavis
  • 209
    • Aaron's Webpage
slopy steering
« on: February 05, 2007, 11:19:13 AM »
What usually causes slopy steering?  I have a 1990 Tracker and get a lot of play in the steering wheel and I'm curious as to what to look for.
thanks
Aaron
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: slopy steering
« Reply #1 on: February 05, 2007, 01:23:55 PM »
Worn out tie rod ends is usually the culprit.  The steering box itself could be going bad, but these things normally last a long time.
1993 4-door Sidekick
4.24:1 t-case
Offline Carnage
  • 2453
Re: slopy steering
« Reply #2 on: February 05, 2007, 01:42:01 PM »
how do you fix worn out tie rod ends?
Offline kirknd4spd
  • 333
Re: slopy steering
« Reply #3 on: February 05, 2007, 02:15:38 PM »
just replace the tie rod ends. you can get them at any auto parts store
Offline ADavis
  • 209
    • Aaron's Webpage
Re: slopy steering
« Reply #4 on: February 05, 2007, 02:25:10 PM »
Awsome!  Will do and it shouldn't be that much. 8)
Aaron
Offline ZukiPower
  • 52
  • Gwendolyne: '93 Kick
Re: slopy steering
« Reply #5 on: February 05, 2007, 07:46:58 PM »
I use to have the same problem with my '93 Kick.  The steering wheel was able to turn of about 20 degrees without any effect on the direction!
The cause wasn't the tie rods but a small rubber-like damper called a rag joint, placed in the middle of the direction column.
I replace it (for about 15$) and everything's fine now.
BTW, that procedure was suggested by peoples on this forum: thanks guys!
 ;D
There's a old saying in Quebec who said: "Grosse corvette, p'tite quequette!".  It means "Big cars are for those who have to compensate for a very small wiener".  Therefore, I love my VERY SMALL Zuki!!!
Offline Carnage
  • 2453
Re: slopy steering
« Reply #6 on: February 06, 2007, 02:23:57 AM »
anyone have instructions?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: slopy steering
« Reply #7 on: February 06, 2007, 07:14:58 AM »
If you are talking about the replacing the rag joint, iZook has an article on the subject.
You can easily find it by doing a search for rag at Ack's FAQ (see link in signature)
Ack
Offline ADavis
  • 209
    • Aaron's Webpage
Re: slopy steering
« Reply #8 on: February 07, 2007, 09:30:22 AM »
Cool, I'll probably replace it this weekend.
This site is awsome ;D
Aaron
Offline ADavis
  • 209
    • Aaron's Webpage
Re: slopy steering
« Reply #9 on: February 08, 2007, 08:55:10 AM »
Well, I checked it out this morning and it doesn't seem to be the rag joint because it doesn't have one.  I looked in both the Hayne's manuel and the Dealer manuel and neither of the two showed a rag joint in the diagram.  I popped the hood on the Tracker and looked and no rag joint.  So I'm back to the the tie rod ends.
Aaron
