bad throttle response
  • 1818 Views
« on: February 05, 2007, 04:24:42 PM »
theres a dead spot right off idle if i blip the throttle... it drives me crazy.. anyone know how to fix this???     87 samurai  1.3l
Offline Low Range
  • 192
    • Low Range Off-Road
Re: bad throttle response
« Reply #1 on: February 05, 2007, 06:05:45 PM »
Offline ZukiPower
  • 52
  • Gwendolyne: '93 Kick
« Reply #2 on: February 05, 2007, 07:59:56 PM »
Use to have exactly the same problem about four years ago.
The cause was a defective throttle position sensor.
That TPS is simply a potentiometer linked to the throttle.  It tell the computer how much throttle is applied at any moment.
Mine have a small crack in is resistive band.  So when the cursor reach that exact point, the TPS send a zero-volt message and the computer react by decreasing the amount of fuel.
I simply change the TPS (take about 3 minutes! It's a modular component with simple solderless plugs) and it run just fine now.  A new TPS worth about 150$ but I manage to find a used one for 50$.
I've seen on some other forums than that particular problem is very common in '90s zukis.
There's a old saying in Quebec who said: "Grosse corvette, p'tite quequette!".  It means "Big cars are for those who have to compensate for a very small wiener".  Therefore, I love my VERY SMALL Zuki!!!
« Reply #3 on: February 06, 2007, 08:40:41 PM »
Is it carbed? Check acceleratorpump. See if gas squrits out when you push throttle. Check with engine off.
