here my tracker sas...
  • 14 Replies
  • 3987 Views
Offline tech
« on: February 06, 2007, 09:08:56 AM »
so i just wanted to share this with the fellow zukers here at zukiworld...this is my 98 tracker with a 16v and 5-speed. its on toy axles and coils. with a 4link rear a radius arm 3link front.
5.71s
loc-rite rear
spool front
14" qa1 coils 200lb in front 175lb in rear.
trail gear hysteer
fj60 power steering box(forward facing pitman arm)
102"wb
35" m/ts
hitches front and rear for winch
mudflaps are just to keep the cops happy
Offline tech
Re: here my tracker sas...
« Reply #1 on: February 06, 2007, 09:10:53 AM »
more pics
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #2 on: February 06, 2007, 10:12:04 AM »
Looks good! Kinda tall tho! Glad to see where 14" QA1 coils will get me tho. Those are the coil over coils, right? Got any flex pics? Your spring rate is what I had planned on using. How is the crawl ratio with the stock x-case and 5.71's?
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #3 on: February 06, 2007, 10:24:46 AM »
Nice rig there...
Offline tech
« Reply #4 on: February 06, 2007, 11:39:31 AM »
crawl ratio is not low enough it needs the trail tough t-case gears. the coils are use for circle track cars i think, i got them from jegs.
Offline RJkick
  • 634
« Reply #5 on: February 06, 2007, 12:26:52 PM »
Most excellent
Offline Jimiweld
  • 234
    • www.fullfusion.ca
« Reply #6 on: February 07, 2007, 04:31:20 AM »
That is excellent, I'd really like to see some pics of it in action when you get it out there. I love seeing the home grown stuff verses buying a bolt on kit, congrats on the great work!!!!!!
If you ever do a detailed write up please post it here for us to read.
Thanks
Jim
;D
Offline tech
« Reply #7 on: February 07, 2007, 10:44:21 AM »
i got some pics of it in a competition but they are on regular film from one of the spectators cameras. i just got a new digi camera that does video too, so as soon as i can i'll post up some vids.
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #8 on: February 07, 2007, 08:34:29 PM »
can you post more detailed pix of the sas setup moore of your frunt setup from all angles i want to put toyo axels under mine and im gathering info on how im going to do it. i want to do my own. how are the bottum links going to twist thay do not have hiem joints on them are you using large polly rings?
Offline tech
« Reply #9 on: February 08, 2007, 10:51:12 AM »
i don't have alot of pics of the front suspention, but i will answer any question you might have. the lower links all have poly bushings on the axle end and johnny joints on the frame end, this setup helps dampen vibes on the road but also does not bind at all offroad. i got all the lower links from suicidedoors.com and they are 37" long. in the 3rd pic of the radius arm peice that comes off the lower link is ajustable to ajust caster and is triangulated but you just can't see it in the pic.
Offline RHodge
  • 523
« Reply #10 on: February 08, 2007, 06:03:38 PM »
looks good   ;D
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #11 on: February 09, 2007, 10:55:05 AM »
Looks Awsome  ;D
Aaron
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #12 on: February 10, 2007, 08:45:38 AM »
hey man...aweasome lookin little trucklet! glad to hear that ya used suicidedoors.com....that is an excellent company...i've built an air suspension system from just their pieces on my 90 dodge dakota....very high quality stuff.....i have yet to break any of it....any other company i could only get about a month or so before i blew out a link or a bag mount got bent/broken....have had the suicidedoors.com suspension pieces for about a year or so by now.....im just amazed that their stuff works for rock crawler style abuse.....great stuff!!!
« Reply #13 on: February 11, 2007, 07:42:26 AM »
Nice work Tech, THat is one awesome looking Tracker  8)
« Reply #14 on: February 11, 2007, 02:44:39 PM »
 ;) SWEET!
