coil spacers center hole bore
  • 2344 Views
Offline museboy07
  • 641
« on: February 07, 2007, 01:12:46 PM »
i just bought some jeep tj coil spacers for my 94 track and i need to know the size to bore the center hole out to....the current hole is 2 1/8" in diamater
Offline TysonS
  • 383
  • www.funinbc.com
Re: coil spacers center hole bore
« Reply #1 on: February 07, 2007, 04:47:30 PM »
2.5" im about 95% sure on that
Offline museboy07
  • 641
« Reply #2 on: February 07, 2007, 06:40:50 PM »
ok thankyou...but this coil spacer has a lip which seems that it would sit down into the coil to keep it in place...if i bore it out to 2.5 in then it will no longer be there...is that lip absolutely needed?
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #3 on: February 07, 2007, 08:02:48 PM »
Offline museboy07
  • 641
« Reply #4 on: February 07, 2007, 09:44:10 PM »
im goin to drill the center to 2.5in so should that be enough? on the one side of the spacer there is a cone shape drill down in bout 1/2" im guessing this is where it will sit on the coil cup?
« Last Edit: February 08, 2007, 04:17:51 AM by museboy07 »
Offline PHX96TRACK
  • 90
« Reply #5 on: February 10, 2007, 08:42:30 PM »
I did mine today 2.5 is right. My daystar 1-3/4" jeep spacers didn't fit in front I had to bore them out. They did fit fine in back tightly... I need a drill bit to finish the rear shock mounts. I'll be done tomorrow if I can figure out the camber situation.
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
