High idle when cold?
  • 2891 Views
« on: February 07, 2007, 08:28:24 PM »
does anyone know how to fix this high idle??  it only does it when its cold intill it gets warmed up  but its at 3,000 rpms    87 samurai 1.3l carb
Re: High idle when cold?
« Reply #1 on: February 08, 2007, 06:08:14 PM »
Anyone know ??? ???
Offline Amilla
  • 1076
« Reply #2 on: February 08, 2007, 11:38:13 PM »
could it be a dirty carb, possibly linkage, and the choke?
Offline raastamon
  • 17
« Reply #3 on: February 08, 2007, 11:55:39 PM »
i have the same problem on my 89tracker.  only when its cold.  I would like to know also.  I am planning on replacing the throttle cable soon, i know its bad. I dont know if thats the cause.
89 tracker,3"body lift, 30"m/t
« Reply #4 on: February 09, 2007, 04:45:21 AM »
Fast Idle adjustment ?? Download the FSM for the Samurai and go through the fault finding stuff on the carb pages
http://www.suzukiinfo.com
Offline ADavis
  • 209
    • Aaron's Webpage
« Reply #5 on: February 09, 2007, 10:45:09 AM »
My 90 tracker goes up to 2,000 rpm at cold start...drives me nuts.  Once it warms up it will go down to normal.
Aaron
Offline WinnipegZuk
  • 23
  • The New Kid On The Block
« Reply #6 on: February 09, 2007, 06:07:14 PM »
lol, fast idle, its supposed to do that. with carbs theres an automatic choke, and basically runs the motor rich untill the heat of the exhaust warms up the the thirmostatic coil, the thirmostatic coil is what controlls the throttle plate when its cold......in turn warming ur engine up.
Offline Eden1
  • 73
« Reply #7 on: February 09, 2007, 07:15:35 PM »
My high idle is on even when hot,I have to hit the gas to get it down.Then I drive and back up it goes??Any help would be appreciated.
