Will 31x10.50-15 tires fit on stock 94 trackers wheels?
  • 3153 Views
Offline museboy07
  • 641
« on: February 09, 2007, 10:59:03 PM »
would they fit??
Offline museboy07
  • 641
Re: Will 31x10.50-15 tires fit on stock 94 trackers wheels?
« Reply #1 on: February 10, 2007, 01:54:18 PM »
does anyone know?????
Offline WinnipegZuk
  • 23
  • The New Kid On The Block
« Reply #2 on: February 10, 2007, 06:18:19 PM »
well i dont know much about tracker wheels but i will tel u this......
if ur tracter wheels 15" in diameter       &      if ur tracker wheels are 7" or more wide ull be ok!
« Reply #3 on: February 10, 2007, 09:21:54 PM »
I've seen it done but the stock Tracker wheels are too narrow.(5"inch wide)
Offline WinnipegZuk
  • 23
« Reply #4 on: February 10, 2007, 10:35:24 PM »
5" wide, u sure, thats like crazy.... if they were like a 6" u might be able to get away with a 9.5" tire
Offline sklope
  • 135
  • BUSHWACKER
« Reply #5 on: February 11, 2007, 04:43:19 PM »
I put 235/75/15 mud terrains (29") on my stock 96 tracker wheels. Even with a 2" body lift, it rubbed quite a bit on the frame and fender at full lock :-\. Really did not like the look either. The wheels kept the tires inside the fender well and did not give it that wider stance that I was looking for. I bought the 2.5" off set wheels from RR and fixed the problem ;D.
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
