Wheel/spacer help
  • 1559 Views
Offline robozuki
  • 33
Wheel/spacer help
« on: February 11, 2007, 03:22:44 PM »
I'm about to put some 235/75 R15's on my stock-height 97 4dr sidekick.  I'm prepared for the minor trimming needed up front (according to folks on this forum), but I need help getting the right wheels.
I want to widen the stance a bit, so that the tires are slightly "outside" of the fenders when looking at it from the front or back.  I was thinking of just getting some inexpensive black steel wheels, or should I just get spacers and use the stock wheels?
If I should get some new wheels, what backspacing should I tell them I need?
Mainly this is a daily driver and desert wheeler, no mud, no snow, no crawling, what's a goodish inexpensivish tire?
Re: Wheel/spacer help
« Reply #1 on: February 11, 2007, 03:51:17 PM »
I've seen 15x8 steel wheels in black for as little as $39. on some web sites. Thats cheaper than some well made spacers. Probably want to go with a 3-3.5 inch backspace? But there are more wheel threads if you use the search button I'm sure.
« Reply #2 on: February 11, 2007, 04:48:58 PM »
With 235s, you could just go with some 15x7s (I've done this twice)
Standard off-set would be 3 1/2- 3 3/4.
