1.3 Sami to 1.6 track/kick swap info needed.
  • 1766 Views
phloop
« on: February 14, 2007, 07:00:36 PM »
I have a few questions on swapping a 1.6 into my Zuki. I have a 1.6 that needs the complete timing belt adjuster set-up. Can I use the adjuster set-up from the 1.3 on the 1.6? And also, can I use the lower timing belt gear from the 1.3 on the 1.6? I have a fancy lower pulley( the grand daddy of the lower pulley that is sold by Rocky road) for the 1.3(has 4 bolt holes), the 1.6 has 5 bolts holding the pulley to the gear.
Re: 1.3 Sami to 1.6 track/kick swap info needed.
« Reply #1 on: February 15, 2007, 05:20:53 AM »
I used the 1.3 pulley on the 1.6 but I'm also using the 1.3 alternator and water pump pulley. I lined the 1.6 pulley up on top of the 1.3 and drilled through the holes using a pillar drill.
It helps to use some sort of round bar through the two centres to keep them centered. You also need to ensure that the timing marks are properly aligned. I don't know about the adjuster.
phloop
« Reply #2 on: February 16, 2007, 08:08:43 AM »
Does any one know about the timing belt adjusters?
phloop
« Reply #3 on: February 16, 2007, 10:20:54 PM »
No one here knows? ???
Never mind, I now no longer need a reply. ;D
If any one else may ever need the info, feel free to ask me. ;)
I guess I may have to update my sig. to include....... awww never mind. :-X
