Oil Pressure guage
  • 11 Replies
  • 5253 Views
Offline Speedracer7c
  • 2210
Oil Pressure guage
« on: January 02, 2005, 07:45:37 AM »
Well today, my battery was dead and I was pissed. So I bought one of those cheesy Oil, Volt, Coolant, setup things. I was wondering, how do you hook up the oil pressure guage. The directions suck.  ??? I know there is the switch for the oil light. I'm sure there is somethign to do with that. Can anyone point me in the right direction?
Offline Cwkick
  • 888
Re: Oil Pressure guage
« Reply #1 on: January 02, 2005, 08:19:51 AM »
This was on a Sami, but it will probably work on a Tracker also.  Just above the oil filter there is the oil pressure sending unit.  Pull it out and replace it with an adapter that will screw in to the block and allow the thin oil "pipe" the goes to the gage to mate up.  Remove the oil pressure light.
I think that will work for you.
Cwkick
  • 2210
« Reply #2 on: January 02, 2005, 08:42:55 AM »
K thats what I was thinking of doing but wasn't sure...thanks man
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: January 02, 2005, 10:02:23 AM »
Cwkick
Great info thanks, dude.
Offline blyota91
  • 71
« Reply #4 on: January 02, 2005, 01:13:15 PM »
When I put an oil pressure gauge on my Toyota I used a T fitting in there so I could retain the stock oil pressure sending unit, that way the light on the dash still functions properly.
1988 Samurai 5inch SPOA and 32X9.5 TSL's  Giggity Giggity
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #5 on: January 02, 2005, 08:20:16 PM »
I bought a Y-piece that screws into the thread of the oilpressurelight, so I can use both light and gauge. I bought another Y-piece to screw into the first Y-piece for the lubrication of the SuperCharger.
Got it from www.autostyle.nl a Dutch Company.
« Last Edit: January 02, 2005, 08:20:33 PM by nitromax »
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
« Reply #6 on: September 20, 2006, 12:03:08 PM »
What size thread is the Zuk sender unit? Also what oil pressure are you getting?
Cheers
James
Offline SKAsammy
  • 79
  • 1991 samurai
« Reply #7 on: September 20, 2006, 03:12:13 PM »
Cheers
James
I would also like to know, i have the volts and temp hooked up but havent gotten around to the oil pressure yet...
1991 SAMURAI
6"spoa
2" body  lift
8000 lb winch
30/9.5/15 BFG all terrains roll on bedliner in and out homemade bumper 1996 Silv. 4" lift 35's many mods
Offline gravity_storm
  • 108
  • The wino and I know
« Reply #8 on: September 20, 2006, 04:43:53 PM »
Check out this thread:
http://www.zukiworld.com/forum/index.php?topic=13321.msg123594#msg123594
safarikick posted picures  ;D
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
« Reply #9 on: September 21, 2006, 04:44:13 AM »
Nice pics but it doesn't state the thread size anywhere.
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
« Reply #10 on: September 21, 2006, 11:40:31 AM »
I don't have much confidence in the plastic tubing which is normally supplied with the gauge kits.  1/8" copper tubing uses the same fittings and, in my opinion, is less likely to develop a leak.  Parts stores usually have it.  When I install it, I always put a ~2" loop in the tubing to allow for movement of the engine.
« Reply #11 on: September 21, 2006, 12:18:53 PM »
I'm looking at an electric gauge, sensor is listed as a 1/8-27NPT, I guess thats the right one then.
