new sidekick needs 33s have searched forum
  • 20 Replies
  • 6703 Views
Offline zuk jockey
  • 32
« on: February 17, 2007, 09:55:51 PM »
             Hello i am new to this board. i have had two sammy's, now living in canada they have all rotted away so i now have a 94 sidekick i have bought with worn 31 10.5 bfg muds. a 3.5 inch body liftand mayby a suspention lift but i cant tell. it has blue springs and control arms. I thought it might be a calmini 2" but struts are grey and rear shocks not calmini. can any ine tell me how to figure out what ive got so i can get an extra 1.5" of lift. if this is a calmini 2" can i put spacers on top of it. if only using 3.5 inch body lift would the 31s fit there, is no rubbing. i have 4 brand new bfg mud terrains just begging to go on
1994 sidekick soon to have 33s
Offline olija
  • 770
    • Check out my cardomain
Re: new sidekick needs 33s have searched forum
« Reply #1 on: February 17, 2007, 11:05:42 PM »
If your A-arms and coils are blue, there is a VERY good chance of your lift being a Calmini. The easiest way to tell if it is a 2" or 3" kit is to check if the kit includes differential drop brackets. The 2" kit does not, while the 3" does.
I'm not sure, but I think if you run a diff drop bracket, you might be able to run spacers on top of the coils...because the bracket returns the CV's to stock angles right? Don't quote me on that because I'm only speculating. You may want to look into this some more. Contact Calmini or Boondox and see what they say.
Offline zuk jockey
  • 32
« Reply #2 on: February 17, 2007, 11:41:25 PM »
 well im not even sure ther is a suspention lift i guess my rear question is how can i tell. does anyone have pix of a stock control arm
Offline zuk jockey
  • 32
« Reply #3 on: February 18, 2007, 12:25:10 AM »
    ok i searched the web and found an install tutorial and my control arms are definetly not stock. now what do i do to clear 33s and i do not want a calmini 3 inch lift. is fender cutting the only way? can i get ifs drop brackets anywhere
« Reply #4 on: February 18, 2007, 05:05:47 AM »
You can fit coil spacers on top of the springs to give some additional lift but you'll have to cut the fenders. You'll probably also need to push back the corners of the footwells to gain some clearance there as well. How much you need to cut depends on the offset and width of the wheels. I have 33x9.5s on 7" rims with 3 3/4" backdpacing. I had to trim the fenders about an inch and push the footwells back about the same distance. The lockstops needed to be adjusted just a little to stop the tyre hitting the frame. I did a trial fit of some 33 x 12.5s on 10" rims and I would have had to cut the fenders back a lot.
The Calmini 2" lift comes with drop brackets although they don't drop the diff as much as the 3" kit. You'll need to check the CV travel to see how much extra drop they can take. Calmini's web site has a good pic of the 2" kit so you should be able to identify all the parts.
« Last Edit: February 18, 2007, 05:15:36 AM by Rhinoman »
Offline lowrezolution
  • 292
  • "Get bent!"
« Reply #5 on: February 18, 2007, 06:04:57 AM »
Where about in Canada do you live Greg?
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline zuk jockey
  • 32
« Reply #6 on: February 18, 2007, 04:28:19 PM »
      just outside peterborough ontario. Im borowing a sawsall this weekend time to get trimming it will be tough i hoped not to have to i got a sidekick with need body kit its almost like its wide body or somyhing about 3 inches wider and not just around the wheel wells all the way to ythe doors. i guess i will have to modify them. I have heard 33s are hard to fit but with 5.5 inches of total lift if my truck didnt flex 33s would fit great. this really makes me miss my little samies soa and 33s those were the days
Offline ZeusZuki
  • 411
« Reply #7 on: February 18, 2007, 10:54:29 PM »
33's are easy to fit. 33x12.50x15 on 8" rims + 3" body lift + 3" Calmini suspension lift kit + trimming of the front guards - ditch the rear bumper and trim the front bumper in an arc to clear the tyres turning arc and there you have it  ;D
Pretty easy really and worth every bit of effort. A Kick on 33's is one VERY capable rig  :o
ZeusZuki  8)
« Reply #8 on: February 19, 2007, 04:49:21 AM »
ZeusZuki  8)
How much backspacing are you running?
Offline zuk jockey
  • 32
« Reply #9 on: February 19, 2007, 10:22:33 AM »
   thsnx for all the info ill try to get pix of the currant stance
Offline zuk jockey
  • 32
« Reply #10 on: February 19, 2007, 10:55:05 AM »
im trying to post some pix bear with me first try
Offline zuk jockey
  • 32
« Reply #11 on: February 19, 2007, 10:59:46 AM »
   tghos pix are with 31s i seem to have prety good clearance. waht about cv angles does it look like i an get more out of spacers?
Offline JayN
  • 220
« Reply #12 on: February 19, 2007, 02:10:16 PM »
ah, isn't it cute
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #13 on: February 19, 2007, 04:56:17 PM »
About the only way I know for sure to tell if you have a 2" or 3" lift is to look at the front coils. If they are blue, you have a 3" and if they look like stock springs you have a 2" lift.
Offline zuk jockey
  • 32
« Reply #14 on: February 19, 2007, 05:10:13 PM »
   they are blue
