How much power?
  • 28 Replies
  • 7768 Views
Offline zaggy
  • 1134
Re: How much power?
« Reply #15 on: June 20, 2005, 03:33:31 PM »
Now i've got the low end picture....what about the top end....Wildgoody how crazy do you think we could get on a 2.0L 16v....I'm thinkin Full built bottom end, balnaced etc, adding about .050 to the lift 20 degrees to the duration custom buildiong an intake to use bosche injectors with the mega squirt box, crank fire ignition then adding................(your turn)
Zag
Re: How much power?
« Reply #16 on: June 20, 2005, 03:38:06 PM »
You know with the right parts a 2.0
could produce 300 HP, but I don't
think it's a good match for a 4x4
For torque, a high compression non
boosted engine would be the most
reliable, but I think more cc are needed
for real power and torque gains
Offline zaggy
  • 1134
Re: How much power?
« Reply #17 on: June 21, 2005, 07:10:49 AM »
Ok back to reality...........
    Are you guys interested in a post with pictures on building a 1.6/8v of 90-100hp. Written so any one with the basics can follow? On a reasonalbe budget.
Zag
« Last Edit: June 21, 2005, 07:11:20 AM by zaggy »
Offline bus_driver
  • 479
  • the voices tell me different things
Re: How much power?
« Reply #18 on: June 21, 2005, 07:20:22 AM »
definately!!!
we use to do 1.8 8v VW engines and they would do nice torque using a 2.0 head and 1.8 bottom g60 infectors and 272 degree cam along with intake and full exhaust
this made a wonder ful engine for street ....good toreque and good top end about 135 hp or so
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
Re: How much power?
« Reply #19 on: June 21, 2005, 07:20:26 AM »
Would love any ideas to get a 1.6 8v moter to around 100hp I was seriously hoping to get around 100-115 out of mine when i rebuild it with some add ons. Was looking at a .20 overbore on rebuild with header and exhaust swap with cam. Any other ideas would be great though.
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
Offline zaggy
  • 1134
Re: How much power?
« Reply #20 on: June 21, 2005, 07:34:10 AM »
     For wilder stuff guys I a pile of info on "Pics of zaggy's engine" and "high performance engine glitch" where I got 113-114hp |removethispart|@ 5900rpm. That will give you the idea of what it takes to get to that power level.
    What I have in mind here is a pretty sane 1.6/8v build up with pics, showing what it will take to get to around a real 90hp, bolt ons, cam and some mild internals.
Whose interested in following that ?
Zag
Offline SnoFalls
  • 1358
Re: How much power?
« Reply #21 on: June 21, 2005, 07:50:15 AM »
This was also my "recipie" for the winter rebuild ... probably some head porting for intake/exhaust flow ... but yea!
I WOULD LOVE TO HAVE AN EXPERIENCED ENGINE BUILDER WRITE UP THE "RECIPIE". I'd even ship cam cores off that I can find for the "experiment" ... find the best grind and then post up the info or sell em ...
Offline SnoFalls
  • 1358
Re: How much power?
« Reply #22 on: June 21, 2005, 08:05:11 AM »
Hey zag ...
Put out a call for parts/donations. I for one would drop $20 to ya to fund the "experiment", and others probably would ship cams, valves, etc from junk cores. Wanna play with 1.3's? lots of them around  ;D
To me a small contribution to get the right recipie will pay off in the long run.
I enjoy the "build" of an engine too. I just hate when "that doesn't work right" ends up meaning I have to redo something :( (e.g. cam grind or compression ratio, or ...). So you figure it out, I made my "contribution" the best I can, and all is good.
Offline zaggy
  • 1134
Re: How much power?
« Reply #23 on: June 21, 2005, 08:11:21 AM »
OK you asked for it........
   I'm setting up the back shop for this extra project now.
But I need to know where I can set up to host the pics, this is something I haven't done before and Wild was good enough last time but this will have a pile of pics so I should set something up...any advice
Zag
Offline Cwkick
  • 888
Re: How much power?
« Reply #24 on: June 21, 2005, 08:50:30 AM »
Zaggy,
This is a site that Explosivo, a Zukiworld member set up.  It works pretty darn well.
http://www.omghi2.us/upload/
Cwkick
Offline zaggy
  • 1134
Re: How much power?
« Reply #25 on: June 21, 2005, 09:24:31 AM »
Thanks guys
    Check out "Do it yerself rebuild" I'm starting now
Zag
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: How much power?
« Reply #26 on: June 21, 2005, 10:10:09 AM »
The biggest things I would like out of the stock 1.6 8valve in my Trackers would be low end muscle and reliability. Being able to lug it down lower and still have some power to pull itself back up would be awesome, but I wouldn't want to sacrifice reliability to do so...
95xl7
Re: How much power?
« Reply #27 on: June 21, 2005, 11:00:08 AM »
I'd like to see about 20 more ponies, so around 195-200 would be nice. ;)
Offline zaggy
  • 1134
Re: How much power?
« Reply #28 on: June 21, 2005, 11:37:23 AM »
Lets see for 95XL7............
    Dual exhaust, custom 2 1/4", dual cats, Turbo mufflers, removable balance tube about 24" back from the manifolds. KN airfilter....yeah that would get about 15hp
Zag
