lift pics
  • 14 Replies
  • 3747 Views
Offline sidekick 4x4
  • 97
  • sidekick
lift pics
« on: February 18, 2007, 10:30:06 PM »
next step is 3" body lift and 31" bfg a/t
« Last Edit: February 18, 2007, 10:38:11 PM by sidekick 4x4 »
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
Re: lift pics
« Reply #1 on: February 18, 2007, 10:39:46 PM »
Sure are braving the elements. Looks Cold.
Is that the BoonDox 3"inch spacers?
Looking good.
  • 97
  • sidekick
Re: lift pics
« Reply #2 on: February 18, 2007, 10:43:24 PM »
yea its freezying here but its fun because we have alot of snow here so its fun driving though feilds and its just the boondox 1.5 spacers but i measued my frame height before and after i did the lift and it raised it 2.5" so im happy with that and it wasnt hard putting them in
Offline zuki4fun
  • 91
  • luv machine
Re: lift pics
« Reply #3 on: February 19, 2007, 05:48:25 PM »
when you put those in did the wheels go back straight or are they slanted still like in the last two pics
  • 97
  • sidekick
Re: lift pics
« Reply #4 on: February 19, 2007, 06:00:13 PM »
yea my front tires are slanted in because of the coil spacers so im going to get an alligment after i get my new tires and rims
Offline Uncivilized
  • 1469
    • Car Domain
Re: lift pics
« Reply #5 on: February 20, 2007, 12:15:21 PM »
You should get an alignment before you put on your new tires and rims, to save your new tires from getting camber wear.
Offline tipover
  • 422
Re: lift pics
« Reply #6 on: February 20, 2007, 04:05:07 PM »
I would put the tires on just before the alignment as different offset of the new tires will change the camber.  it changes it because of the difference in leverage on the A arm.  when I put lafger tires on the, half the camber issue was eliminated and it slightly changed the height. the camber change about .5 degrees with the larger tires.  Just my experience.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline Armour
  • 360
Re: lift pics
« Reply #7 on: February 20, 2007, 04:13:32 PM »
Tire size should not affect camber angles.
  • 97
  • sidekick
Re: lift pics
« Reply #8 on: February 20, 2007, 06:54:18 PM »
yea i no im gona put my new tires on the day im getting the allingment
Offline tipover
  • 422
Re: lift pics
« Reply #9 on: February 20, 2007, 08:38:01 PM »
Your right, off set does.
« Last Edit: February 20, 2007, 08:39:35 PM by tipover »
  • 97
  • sidekick
Re: lift pics
« Reply #10 on: February 21, 2007, 04:42:28 PM »
whats camber wear
Offline tipover
  • 422
Re: lift pics
« Reply #11 on: February 21, 2007, 11:14:42 PM »
tires are tilted in or out at the bottom cause un equal were on tread.
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: lift pics
« Reply #12 on: February 22, 2007, 05:20:19 AM »
Wider tires act like different offset to a degree, so yeah, tire size can affect camber a little.. but mostly wheel offset.
Offline Armour
  • 360
Re: lift pics
« Reply #13 on: February 25, 2007, 01:22:51 PM »
Tire size or offset should not effect camber. It may put more stress on stuff but shouldn.t really effect things like angles
Offline tipover
  • 422
Re: lift pics
« Reply #14 on: February 25, 2007, 04:23:54 PM »
If you take the tire off and bolt a spacer 10 feet long with a tire on the end, it will set at a different height do to the leverage on the spring.
If that doesn't help, Sorry I can't help you.
