fuel pump relay on 1.6 8valve
  • 9 Replies
  • 2940 Views
Offline kirknd4spd
  • 333
« on: February 19, 2007, 01:34:20 PM »
where is the fuel pump relay at on my 8 valve 1.6L sidekick? my repair manual is no help at all.
Offline westvilleguy
  • 53
Re: fuel pump relay on 1.6 8valve
« Reply #1 on: February 19, 2007, 02:57:18 PM »
on my automatic its up under the dash on the drivers side by the fuses, but i cant find it on my 5 speed
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Offline kirknd4spd
  • 333
« Reply #2 on: February 19, 2007, 04:01:59 PM »
thanks!  ;D ill check that in the morning. and mine also has an auto
« Reply #3 on: February 19, 2007, 09:58:17 PM »
Look for your computer. Relay usaly mounted to ecm.
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #4 on: February 19, 2007, 10:45:13 PM »
the fuel pump relay is located on the heater unit under the dash.
Offline kirknd4spd
  • 333
« Reply #5 on: February 20, 2007, 08:26:53 PM »
nope, its only on the heater unit on 16 valves. mine was also on the drivers side under the dash.
i just needed to know where it was so i could test it to see if the relay or fuel pump had died. unfortuately, my fuel pump is dead, so i need a new one.  :'( any idea how expensive a new fuel pump is?
thanks for all the help!  ;D
  • 238
« Reply #6 on: February 20, 2007, 10:34:44 PM »
brand new fuel pumps range from $140-$380
« Reply #7 on: February 21, 2007, 05:09:04 AM »
Have you checked the wiring behind the taillight and the connections to the top ofthe tank. They are often quite troublesome.
Offline kirknd4spd
  • 333
« Reply #8 on: February 21, 2007, 08:50:15 PM »
yeah, i had checked all that. i had it narrowed down to the pump or the relay, but couldnt find the relay. i pulled the tank out today, and tomorrow im getting my new pump.  ;D
Offline chet
  • 556
  • Zuki time!
« Reply #9 on: February 22, 2007, 02:24:28 PM »
chyeck the pump first could be the comp.
