Is My Tranny Going Out?
  • 2798 Views
Offline W.O.T
  • 38
« on: February 19, 2007, 01:43:08 PM »
i started to have a problem getting my samurai in 1st gear.  its getting worse pretty quick and sometimes it takes me about 30 seconds of trying to get it to go into gear.  all other gears work fine and shift properly.  does something need to be adjusted?  or is my tranny going out?
Offline Amilla
  • 1076
Re: Is My Tranny Going Out?
« Reply #1 on: February 19, 2007, 05:58:33 PM »
synchro might be going out, 1st gear does get quite a bit of work.
Nothing you can do to adjust it, its just a replacement thing.
Amilla
Offline zuk jockey
  • 32
« Reply #2 on: February 19, 2007, 06:11:01 PM »
    before i replaced my trans i would make sure clutch is fully engaging if not clutch can syop you from puting vehicle into gear
1994 sidekick soon to have 33s
Offline mlovetripp0
  • 204
  • do more with less
« Reply #3 on: February 19, 2007, 07:28:50 PM »
check your cable for spliting
87 sammi
Offline W.O.T
  • 38
« Reply #4 on: February 19, 2007, 07:41:31 PM »
thanks for the replies, i tightened up my clutch cable and it has helped but i havent had a chance to really take it out for a good drive yet.  ill see how it works tomorrow.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: February 19, 2007, 08:04:27 PM »
does it go into gear easily when its not running? Could be clutch adjustment or a bad cable. Is it easier when its warm?
Mike
Offline W.O.T
  • 38
« Reply #6 on: February 21, 2007, 11:14:50 PM »
its still acting up.  it goes into gear perfect when the engine is not running clucth in or out.  when i can get it into first when its running i have to be at a complete stop.  If im rolling there is no way it will go into 1st.  All other gears work perfect.  i tied adjusting the clutch but no luck there.
Offline Amilla
  • 1076
« Reply #7 on: February 22, 2007, 12:36:03 AM »
when the car is off you can force the synchro gears to mesh up, but once its running they cant do that, there acting like a stright cut gear.  All of my other rigs that i have had that  wont go into first (or any other gear).  So i re-build the tranny, new synchro,  Shifts like a dream.
Will it go into gear while rolling if you double clutch?
I have to do that every now and then, seems to work fine.
Amilla
