Hagen front end spacer
  • 2417 Views
Offline ZukiDuke
  • 40
  • Budget Beaters Rock
« on: February 20, 2007, 11:48:20 AM »
Hey guys i am getting ready to do the hagen front end widening on my track, I was wondering how thick of a spacer is needed instead of chopping up a bunch of axles I dont have. I have the tools to make it I just don't know how thick it needs to be ?
Thanks
89 SideKick JLX 3spd Auto 5.13's Lockers, Homemade 3" BL , Digger Spacers, 31 " LTB's
95 LSI DD
95 Tracker G/F DD
88 Sami in the works
Re: Hagen front end spacer
« Reply #1 on: February 20, 2007, 01:10:39 PM »
I'm pretty sure it needs to be the thickness of two axle flanges, according to the write up. Anyone care to comment ?
« Reply #2 on: February 20, 2007, 05:31:30 PM »
That is how wide I made yours.  ;)
I'll email you later.
Offline ZukiDuke
  • 40
« Reply #3 on: February 20, 2007, 05:45:47 PM »
Did you make it out of steel or aluminum? I was thinkin of steel so I could weld it to my stub axle, or is just bolting it together ok ?
95 LSI DD
95 Tracker G/F DD
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: February 20, 2007, 06:06:29 PM »
Ive heard of people making them out of aluminum with success but I needed to weld my steel ones cause I would stretch the bolts and break it.
Mike
« Reply #5 on: February 20, 2007, 06:12:05 PM »
That one is made from aluminum.  That one is for the left side.
The one for the right side will need to be made out of steel, so it can be welded to the modified stub shaft.
Here is a pic of the modified stub shaft with a steel flange for the right side.  The flange is just tacked in place in these pics....it will be fully welded later.
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #6 on: February 20, 2007, 06:26:24 PM »
i would weld it less chance of movement, double sheer point.  stan
