Front Coils?
  • 12 Replies
  • 3280 Views
Offline BigRubbersOffRoad
  • 35
  • Sick Kick
Front Coils?
« on: February 21, 2007, 01:55:02 PM »
I'm looking for a little help. My calmini 3'' coils are worn out under the weight of my 4dr, I guess the winch and bumper are to much. It looks like I have 3 choices on new coils, what should i do???
1. New calmini 3'' coils
2. Boondoxmotorsports 3'' coils
3. OME 4dr heavy duty coils
I want to do the OME coils but, on the RR website it's only 1.5'' of lift.
What will work the best for me??
94 Sidekick- Trail Slayer SAS, 36'' Iroks, TT 4.24 crawler gears.
88 Samurai- 16v swap, 5.12 gears, 33'' Cooper STT
Re: Front Coils?
« Reply #1 on: February 21, 2007, 03:10:31 PM »
Not with a 3" lift they (OME) won't. I think you may want to stick with the 3" lift coils. JMO.
  • 35
  • Sick Kick
Re: Front Coils?
« Reply #2 on: February 21, 2007, 05:03:46 PM »
does anyone know if calmini and Boondoxmotorsports 3'' coils are the same?
Offline olija
  • 770
    • Check out my cardomain
Re: Front Coils?
« Reply #3 on: February 21, 2007, 06:59:59 PM »
Get the OME coils and put spacers on top of them. Problem solved...sort of anyway.
Offline cj
  • 1276
  • I drive a really big ATV
Re: Front Coils?
« Reply #4 on: February 22, 2007, 01:23:38 AM »
If you want to use Old Man Emu then their XL-7 coils would be the ones to look at. They lifted my 2.0 V6 LWB Sport 3". The 1.6 is lighter so you would get a bit more with stock arms. The Calmini arms may reduce that a bit but you could always add spacers if needed. At some point I will try them in place of the Calmini springs to see how they work with the arms but it won't be for a while yet.
Re: Front Coils?
« Reply #5 on: February 22, 2007, 04:55:30 AM »
The only thing with the OME coils you may have a problem with is the spring rate. They may be a bit too soft, and sag some with the extra weight you have.
Offline cj
  • 1276
Re: Front Coils?
« Reply #6 on: February 22, 2007, 12:55:20 PM »
I used to run the ARB winch bar and an 8000lb winch and an Optima battery up front and never had a problem. I know Mike Hagen ran some OME GV coils at one stage in the front of his with a modified Calmini setup but can't remember the configuration.
Offline chet
  • 556
  • Zuki time!
Re: Front Coils?
« Reply #7 on: February 22, 2007, 02:11:21 PM »
ome gv coils would work great. they are built for the extra weight of the V6.
The calmini coils are alright but mine are starting to sag a bit as well.
Oh if you are ordering OME coils get the front struts as well. I just put them in on the weekend and holy crap what a difference! soooo smooth!!!!
Offline Praise Him
  • 256
Re: Front Coils?
« Reply #8 on: February 22, 2007, 06:27:02 PM »
ill give you 50 bucks for the used coils you have
sammy/toy axles/locked/geared/cased/36's
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Front Coils?
« Reply #9 on: February 22, 2007, 06:52:30 PM »
I belive the coil I ran was a OME 962. It was a v6 GV auto coil. I also know someone who cut one ring off the Calmini coil which raises the rate and added a spacer to restore the height. It was cheap and has been a good long term fix for him.
Mike
  • 35
  • Sick Kick
Re: Front Coils?
« Reply #10 on: February 22, 2007, 07:38:38 PM »
Does it mater using the OME coil with the Calmini control arm? I don't think it will make a difference.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
Re: Front Coils?
« Reply #11 on: February 23, 2007, 10:35:00 AM »
I have a set of the heavy duty sidekick front OME coils. they are used and i am asking 50 bucks plus shipping for the pair. i believe they are supposed to be 1.5"  lift as they were part of the 4.5" rocksteady kit from Rockyroad (2" body, 1.5" OME coil, 1 inch spacer)  In a couple weeks I will be selling the whole kit which currently has the V6 GV coils on it ( I did the hagan widening mod which drops the front a bit) which is why I swapped coils
thanks,
Hutch
  • 35
  • Sick Kick
Re: Front Coils?
« Reply #12 on: February 23, 2007, 01:52:17 PM »
I'm going to order the calmini coils, the old ones lasted me 5 yrs of hard wheelin'. This way, I know what i'm getting, and I know how they work.
