tires????
  • 2119 Views
Offline sidekick 4x4
  • 97
  • sidekick
tires????
« on: February 22, 2007, 05:40:40 PM »
how big of tires could i run on a sidekick with out having to get new gears i have 1.5" coil spacers and i just ordered a 3" bodylift
1990 sidekick,snorkel, 2.5" coil spacers, procomp shocks and strut extenders, 3" calmini body lift, 30" A/T,CHEERY BOMB MUFFLER
Offline sklope
  • 135
  • BUSHWACKER
Re: tires????
« Reply #1 on: February 22, 2007, 06:10:05 PM »
I've got a 2 inch lift on my tracker with 275/75/15 M/T's and it does OK. You will get about a 5 to 7 mile per hour drop on a good incline. Im planning on getting some different gears, just have'nt decided on which ones yet!
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
  • 97
  • sidekick
Re: tires????
« Reply #2 on: February 22, 2007, 06:47:30 PM »
yea i want to get the 31" super swampers but i want to no if it will still have the power to go of road with the stock gears
Offline ROSS
  • 1412
Re: tires????
« Reply #3 on: February 22, 2007, 06:51:34 PM »
it's okay .just sucks for rock-crawling.  before i got my t-case gears i'd tried it and toasted a clutch bigtime toast
  • 97
  • sidekick
Re: tires????
« Reply #4 on: February 22, 2007, 06:55:48 PM »
so do u think i would burn up my clutch with those tires if i went off roading
Offline ROSS
  • 1412
Re: tires????
« Reply #5 on: February 22, 2007, 07:00:46 PM »
i was trying to climb some pretty big rocks . if you have to go to fast you have no control. makes for good way to break things. t-case gears are well worth the money if you like to rock-crawl.
Offline trackenator
  • 38
Re: tires????
« Reply #6 on: February 23, 2007, 02:55:12 PM »
31s will fit fine with your set up 33s with maybe a little fender trimming. clutch will be fine if you stay off the rocks and just do normal off roading(mud,small hills,ditches etc) also alot depends on how well you can operate the clutch system .good luck and have fun.
