clutch start cancel
  • 2261 Views
Offline Amilla
  • 1076
clutch start cancel
« on: February 24, 2007, 10:24:15 AM »
How do i dissengauge the clutch start?  Is there a sensor that i have to ground out or do somthing of that sort?
Thanks
Amilla
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: clutch start cancel
« Reply #1 on: February 24, 2007, 10:45:40 AM »
It's a 2 prong connector that's mounted up on the clutch pedal.
The easiest way to disengage it is to pull the 2 wires, and use a standard fuse (should be a spare in your fuse box) and that will jump the connection letting you start it without having your foot on the clutch.
It takes about 30 seconds also.
1993 4-door Sidekick
4.24:1 t-case
Offline RHodge
  • 523
« Reply #2 on: February 24, 2007, 11:11:46 AM »
first thing I did when I got mine
Offline ROSS
  • 1412
« Reply #3 on: February 24, 2007, 06:09:43 PM »
I installed a toggle switch on mine . so when I let someone else drive it I just flip the switch.works normal.  easy to do safer if the wife drives it.
                             Ross
Offline mntracker
  • 314
  • MORNEAU MVP
« Reply #4 on: February 24, 2007, 06:35:17 PM »
That would be nice to add auto start,huh?
Offline ROSS
  • 1412
« Reply #5 on: February 24, 2007, 06:40:30 PM »
comes in handy rock-crawlin .  start it up in gear.
Offline Amilla
  • 1076
« Reply #6 on: February 25, 2007, 10:42:24 AM »
ya that is my number one use for that, when it floods out on somthing you can always ride it up on the starter.  Low enough gears and it does it just fine hahha.
Thanks for all the information
Amilla
