red hot exhaust manifold
sidekick101
128
best site on the net
February 24, 2007, 09:43:43 PM »
i need to get a new o2 sensore for sure because the threads are gone and it popin out. but i went to put it back in tonihgt and the manifold was glowing red. i knwo thats not normall. i check the back and shes blowing out fine? any ideas? would a new manifold/ header get rid of this or would i just write a header off if i bolted a new one on. HELP!!! please
1993 sidekick JX, 2 dr, soft top, automatic,
mrfuelish
2862
13
you must have a perception problem.
Re: red hot exhaust manifold
February 24, 2007, 09:59:15 PM »
If your not running it hard up a hill it's running lean, look for vac. leaks or a bad egr valve or your sucking air into the exhaust some how or your down pipe collapsed inside or your cat could be plugged ect.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
zuk jockey
32
February 25, 2007, 06:05:19 PM »
check timing out ive had this happen rotor out 90 deg melted my plugs be sure to check the condition of the plugs . could also be a pluged cat
1994 sidekick soon to have 33s
sidekick101
128
Reply #3 on:
February 25, 2007, 06:51:21 PM »
i don't think its a plugged cat because it still flows fine out the back. but the o2 sensor does fall out so maby thats making it heat more then normal?
