have a 87 zuk want to up grade to a better motor
  • 1951 Views
Offline pcous
« on: February 28, 2007, 02:49:58 PM »
want to know what matches up the best with out making a red neck vehicle just get a good bang for my buck
Offline ROSS
  • 1412
Re: have a 87 zuk want to up grade to a better motor
« Reply #1 on: February 28, 2007, 03:01:25 PM »
go with the 1600 conversion .  easy to do and makes a big difference
Offline smalltowncowboy
« Reply #2 on: February 28, 2007, 03:13:28 PM »
i am going to pick up an 87 sammi on tuesday. i dont know what kind of extreme horse power im going to be looking at but i can imagine. so i am also interested in power upgrades.
your like a prize bass, i dont know weather to eat you or mount you.
Offline GmManDan
« Reply #3 on: March 01, 2007, 03:02:37 AM »
Hello looks we we are in the same boat. All I have found is the 1.6 conversion from the tracker but that is about the only one that they say will bolt right up. If you find out anything else that will work please let me know. I also have a 87 zuki that needs some more hp. Thanks
1999 Gmc sierra 4x4 5.3
1987 Suzuki samauri ,soft top, 5 inch spoa, 3 inch body ,31 tsl radials ,1.6 Efi swap in prgoress.
« Reply #4 on: March 01, 2007, 05:11:30 AM »
It doesn't quite bolt up. It needs an adapter plate or some fabrication. If you don't have a lift then you will need to modify the oil pan and pick up pipe. Try and get one with all the bits like the starter and alternator.
