stronger CVs or shafts for my vit
  • 3424 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« on: March 04, 2007, 06:16:35 AM »
what have people done?
what is easiest? or cheapest?
what parts are easily obtainable?
and how's the easiest way to adapt them on a vit?
i've broken 4 CV joints in as many outings. i'm kinda getting tired of chasing left hand side shafts.
thanks
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: stronger CVs or shafts for my vit
« Reply #1 on: March 04, 2007, 07:30:58 AM »
Ive heard toyota cv shafts work well, Although I have never tried it yet.  nor is mine lifted.. waiting for diff drop brackets.
Offline MRDEAN40
  • 20
« Reply #2 on: March 04, 2007, 01:24:19 PM »
Here is a place to start; http://bbs.zuwharrie.com/index.php/topic,52575.0.html
Do a search on the subject, there is a lot of material out there on this.
Offline Fity
  • 49
« Reply #3 on: March 04, 2007, 04:15:19 PM »
Or you could try this mod.
http://www.zukiworld.com/month_040103/feature_hagencvshaft.htm
I think I may do one of these mods when I run out of spare standard CV's. :)
Offline SiKiD_01
  • 574
« Reply #4 on: March 05, 2007, 06:07:54 AM »
i'm already running two left hand side shafts, but the left hand shaft on the right hand side bottoms out sometimes. i need to widen my vit a la hagen widening.
i know all about the chopping bit, but how does the outer fit into the vit hub, lockout, and spindle? how are they the same when you need to machine out the spindle when using yota shafts?
EDIT: ok, ok, i got it now. you chop the inner 3 bolt flange, and you chop the outer bell to use the outer shaft. and you need to weld them onto the donor shaft. ok, i see now.
so now i need to go and measure how long my cv shafts are, and see if i can find some donor shafts the same-ish length.
« Last Edit: March 05, 2007, 06:13:16 AM by SiKiD_01 »
Offline Fity
  • 49
« Reply #5 on: March 05, 2007, 02:49:08 PM »
Yeah that's it. :)
I am thinking of some Toyota Prado, as the inner CV uses 3 ball races instead of 6 ball bearings, hard to explain, but they look real tough.  The Mitsubishi Pajero also use a very similar 3 bolt flange, this might make the mod easier.  These are just things that I have seen and stored in my memory bank for future use. :)
