Auto trans swap
  • 20 Replies
  • 5302 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Auto trans swap
« on: December 28, 2004, 06:27:04 AM »
Has anyone ever swapped in a 4speedtrans in a trakick? If so what are the pro/cons. any info would help.
    Kevin
Offline idaholwb
  • 772
Re: Auto trans swap
« Reply #1 on: December 28, 2004, 07:21:51 AM »
 Do you have a 3 speed auto now? If so, I think the 4 speed is the same length. Mechanically speeking, it would be straightforward. But you need the wiring to go with the 4 speed and the computer too. Hope you got or want a 16v, cause that is the only way I know of it working.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Auto trans swap
« Reply #2 on: December 28, 2004, 10:10:54 AM »
Thanks, I heard that it might be a little longer. I was wondering if it had a lower 1st. gear?
   Thanks
     Kevin
Offline mesjr2004
  • 422
Re: Auto trans swap
« Reply #3 on: December 28, 2004, 01:08:20 PM »
i was told u didnt need the computer for the auto to work. was thinking of replacing my 5spd w a auto. so it wont work w/out computer?
Offline Speedracer7c
  • 2210
Re: Auto trans swap
« Reply #4 on: December 28, 2004, 01:11:49 PM »
A 3 speed will work without the computer, but the 4 speed i believe has electronic tourqe converter lock up. Someone correct me if i'm wrong. That is why the computer is required.
Offline mesjr2004
  • 422
Re: Auto trans swap
« Reply #5 on: December 28, 2004, 01:16:18 PM »
how do you tell the difference between the 2?
  • 2210
Re: Auto trans swap
« Reply #6 on: December 28, 2004, 01:23:15 PM »
Between the two what......? Transmissions?
Offline mesjr2004
  • 422
Re: Auto trans swap
« Reply #7 on: December 28, 2004, 01:25:27 PM »
yes, the transmitions
  • 2210
Re: Auto trans swap
« Reply #8 on: December 28, 2004, 01:26:53 PM »
I don't know what the difference is in them cosmetically as far as the housing's go or if the dimensions of the transmission's are even different. i do know that the 4 speeds have a overdrive button on the shifter, so you could look for that I guess.
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
Re: Auto trans swap
« Reply #9 on: December 28, 2004, 01:34:31 PM »
Heres the best way I know of to convert a 4speed auto to a 5 spd stick.
1.   Remove the soft top from the car
2.  Take off the radiator cap
(anyone know where this is going?)
3.  sell the car for a reasonable price
4.  Buy a new identical model in 5 spd stick for a good price.
5. Re-install the top
6.  Screw on the radiator cap
7. Auto to stick change out complete !
No problems making it fit or worrying about the computer!!!!
Well, that is the way I plan to do it when I get tired of my 4speed auto and want a stick!!!
  • 2210
Re: Auto trans swap
« Reply #10 on: December 28, 2004, 01:43:58 PM »
Sounds pretty damn failsafe!!! Hahah......
Offline 1bigtracker
  • 3409
Re: Auto trans swap
« Reply #11 on: December 29, 2004, 08:41:54 AM »
yea but what if the radiator cap dosen't fit???  i wouldn't know what to do :-/ ;D
stu
Offline jerryp58
  • 449
Re: Auto trans swap
« Reply #12 on: December 29, 2004, 08:57:14 AM »
Kevin
I've been wanting that extra gear or two for my Tracker too.
I was also under the impression that the 4-speed auto was longer (and only sold in 4-dr models).  I think if I go that route it will be with a donor engine/trans/computer from a later model.  I've never been able to get a clear answer on whether or not the drive shafts are the same length as on the 3-speed (if the dimensions of the two trannies were different, then unless the transfer case is different, I would think that the driveshafts would have to be different also.
All that complication has made me consider a 5-speed manual, but that requires a lot of conversion too  :-/
Please post any useful information you find.
Jerry
Offline dwcrisp
  • 212
Re: Auto trans swap
« Reply #13 on: December 29, 2004, 10:49:41 AM »
I may be Major Dummy but isnt a drive shaft change out about the easiest part of the whole deal?
I still say sell the car and find one you like with the right trans set up.  I love my 98 4 speed auto but would gladly sell it if I could get an identical quality 98 5 speed stick.
PS any bites? 98 green tracker two door rag top.  Green and clean, no dents, no rust, shines, runs great, 2" lift, 235X15 ATs,  only asking $15000.00
Ok only joking. . . but Tracks and Kicks are like a dime a dozen here in central FLorida.  You can find what you want if patient. . .
« Last Edit: December 29, 2004, 10:52:11 AM by dwcrisp »
Offline mesjr2004
  • 422
Re: Auto trans swap
« Reply #14 on: December 29, 2004, 11:33:41 AM »
i was wanting an auto in my traker, i paid more for my tires than i did my daily driver tracker, i hate spending money and i like working on shtuff. i have a auto i was wanting to put in it but no harness. did they ever put a 4spd auto behind a 8v ?does someone make a harness to do this?
