help instrument panel aint lighting.....
  • 2112 Views
Offline CHiLLiPEPER_808
« on: December 28, 2004, 08:11:06 PM »
I need some help, my instrument panel aint lightin up. I changed the dimmer switch, that didnt work, so i changed all the bulbs and still that didnt work. So whats next to do? if all that failed? OH YEAH I HAVE A  90 TRACKER.
« Last Edit: December 28, 2004, 08:13:24 PM by chillipeper_808 »
Offline jerryp58
  • 449
Re: help instrument panel aint lighting.....
« Reply #1 on: December 28, 2004, 09:20:15 PM »
The fuse?
Any wiring changes recently?
I think I've pulled the instrument panel out, if not completeley off, but I can't remember, does it just have one electrical connection on the back?  I'll take a look at the service manual later.
Jerry
Re: help instrument panel cluster aint lighting..
« Reply #2 on: December 28, 2004, 09:26:18 PM »
ya i did check all the fuses.. but the whole wiring set up just confuses me.
« Reply #3 on: December 30, 2004, 05:11:18 PM »
bump
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #4 on: December 31, 2004, 02:01:55 AM »
Is it just your instrument cluster (Speedo, Tach, signals) or the entire dash board including climate controls and if you have an AT the gear select?
The instrument cluster has two data cables that plug in the back along with the analog speedo cable.  Make sure they are properly attached and clean.  The Speedo cable has grease on it, don't clean that off.
Other then that, it could be a kink somewhere between the cluster and it's power source.
« Last Edit: December 31, 2004, 02:03:48 AM by In_Flames »
