Trackick gearbox in sammy/propshaft question?
  • 0 Replies
  • 1363 Views
Offline the rat
  • 11
« on: March 06, 2007, 02:55:05 PM »
I've installed the tracker transmission and transfer box into my samurai. The rear prop is offset a few inches from the original position of the samurai transfer box.
What are my options to run this? Can i have a custom double u/j prop made up (is it even possible to run a prop  like that??) or will i have to shorten a tracker axle to keep the prop angle straight???
I need to keep the 3.7 samurai gears in the axle so if i have to use a tracker axle can i fit these?
If you only make one mod.. make sure its a td engine!
95 Sj high top
Volkswagen1600 TD Intercooler
Petroworks clutch 2" backspaced wheels 31x11.5x15
