snorkel
  • 47 Replies
  • 10443 Views
Re: snorkel
« Reply #15 on: December 22, 2004, 02:47:45 AM »
Looks like a good way to drown your
engine in a water crossing  ;D
Side Note:
THIS IS POST 2700   8)
Offline 1bigtracker
  • 3409
Re: snorkel
« Reply #16 on: December 22, 2004, 02:49:34 AM »
Side Note:
i'm comin!  i have the next 2 weeks off from school, betta watch ya back! 8) ;D
stu
mudfkr
Re: snorkel
« Reply #17 on: December 22, 2004, 04:51:40 AM »
I've installed the safari snorkel to mine.
Install is easy if you take your time and follow the instructions, it comes with a template to stick on your fender that has all the necessary holes marked on it so it's just drill and bolt on really.
I found the hose under the fender that joins the snorkel to the original air intake a bit short in th over lap so I replaced mine with a longer bit of good quality rubber hose, other than that the kit has all you need in it.
I went to a bit more effort than most to seal mine properly  seems it spends alot of time in rivers, instead of using silicone I used a 3m product called scotch weld
DP 8005 which is more like a cement that will bond rubber to LDP (what the snorkels made of) . I did silicone it first then  tested it in the river but still found water to be getting in some where with the silicone that when I took it off and 3m'd it all up  ;D.
Don't for get to seal any drain holes in your air box etc  I put a small tap in mine so I could open it and check if any water is getting in and drain any rain water that might find it's way in.
I only fitted mine  for the fact that I play in water alot and was  not  looking for the ram air effect to increase HP which I haven't noticed any way  ::) so I'd say if you after extra HP you won't find it with a snorkel.
Cheers Shane
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: snorkel
« Reply #18 on: December 22, 2004, 05:00:14 AM »
It's MY Gnewt on the RRO page!  It has paid for itself more than once!
I love it!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline hcgalvin
  • 1695
    • Granite Path
Re: snorkel
« Reply #19 on: December 22, 2004, 05:52:24 AM »
I love it!
Hi Bob!
We gonna do Lion's back this EJS? Last year was exciting!
« Last Edit: December 22, 2004, 05:53:18 AM by hcgalvin »
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: snorkel
« Reply #20 on: December 22, 2004, 07:13:15 AM »
You betcha Heather!  Can you bring a camcorder this year?  And this year, YOU can drive, right?  We'll still take the Gnewt if you want, but I KNOW you can do it!
Bob
Offline mahimahimo
  • 377
Re: snorkel
« Reply #21 on: December 22, 2004, 09:49:33 AM »
yea i ordered mine cause im always playin in  water .....  but im curious how big the holes are that u have to drill in
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: snorkel
« Reply #22 on: December 22, 2004, 09:49:35 AM »
I have an ARB snorkel also.  Real easy to install.  Looks good and for the money, it's paid for its self!!!
It just depends on what you want and have.  The ARB looks good but the PVC one's are cheep and if its a trail bomer I'd go that way.
32 MTR's Warn 8000i
Offline mahimahimo
  • 377
Re: snorkel
« Reply #23 on: December 22, 2004, 10:06:11 AM »
im phyced for mine.... but its on backorder and they said it would be here next week... any one know how big the holes are u have to drill and if i can just drill em or if i gotta use a cutting tool to get em out...... yea i deff needed it i had some close calls and i love playen in the water as bad as that is lol
mudfkr
Re: snorkel
« Reply #24 on: December 22, 2004, 12:30:29 PM »
I can't find the instructions that came with mine but from memory the hole is around 80 mm's. I used a hole saw to do mine. Remember to take your time aligning the template or you'll have a chet fight trying to make things fit.
Offline mahimahimo
  • 377
Re: snorkel
« Reply #25 on: December 22, 2004, 02:02:50 PM »
thanx...... now i no what im in for and it is getten me so mad that the thing is on back order lol
                                                    -mo
mudfkr
Re: snorkel
« Reply #26 on: December 22, 2004, 02:39:41 PM »
Mo,
heres the point of no return....
;D ;D
Did you make sure you ordered the right one  as there is one for th 8v and one for the 16v ?
Offline mahimahimo
  • 377
Re: snorkel
« Reply #27 on: December 23, 2004, 06:12:13 AM »
ummm idk now im callen rocky road .... cause all it said was a snorkel for up to a 94 tracker lol
mudfkr
Re: snorkel
« Reply #28 on: December 23, 2004, 06:34:03 AM »
Just rang a mate  who's the local ARB agent and checked part #'s for ya,
8v is # SS 800 HF, Covers Carb and TBI
16v is # SS 850 HF,Covers all MPI
;D
Offline mahimahimo
  • 377
Re: snorkel
« Reply #29 on: December 23, 2004, 06:38:18 AM »
yea i apreciate that ..... but the only thing is that rocky road hasnt gotten one in  in about 2 years!!!!!! but "supposedly" they might be getten one in next week. yea any one know any where else i can pick one up from
                                               -mo
