snorkel
  • 47 Replies
  • 10440 Views
Offline mahimahimo
  • 377
snorkel
« on: December 20, 2004, 11:44:27 AM »
i was wondering if any one has any pics of a snorkel that rocky-road sells after install and how  hard it was to install and what u noticed
thanx
                               mo
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
Re: snorkel
« Reply #1 on: December 20, 2004, 08:17:55 PM »
Yep, I'd like to see one too, never seen one from the snorkel side, just that one pic on RR's site.
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline explosivo
  • 3157
Re: snorkel
« Reply #2 on: December 20, 2004, 10:45:13 PM »
*cough*wasteofmoney*cough*
Black PVC and a cone filter get the job done for a whole lot less dough ;)
omghi2.us[/url]
Offline 1bigtracker
  • 3409
Re: snorkel
« Reply #3 on: December 21, 2004, 03:25:08 AM »
but not everone is going for the hard core look of PVC.  and dosn't PVC get hard and brittle after it sets in the sun too long???
stu
Re: snorkel
« Reply #4 on: December 21, 2004, 04:50:55 AM »
Black ABS is sun resistant
« Last Edit: December 21, 2004, 05:31:58 AM by wildgoody »
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: snorkel
« Reply #5 on: December 21, 2004, 05:22:48 AM »
The black pipe, ABS, has some advantages over PVC. It's lighter, more resistant to tempurature changes and chemicals plus it's more flexible than PVC. It's already black too. I've always wondered if a steam box like woodworkers use could be used to shape it.
Re: snorkel
« Reply #6 on: December 21, 2004, 05:33:37 AM »
I wondered if one of those plastic
welder setups from Harbor could
fuse sections together, that or have
a blow mold made to mas produce
these things, and for less than $$$
Offline TN_Tracker
  • 1113
Re: snorkel
« Reply #7 on: December 21, 2004, 08:06:41 AM »
You're thinking like me. I wonder why nobody else seems to want to mass produce snorkels for the US market? The cost to manufacture can't be too much after start up.
Offline Baloo
  • 84
Re: snorkel
« Reply #8 on: December 21, 2004, 08:36:50 AM »
 ???What about bending exhaust tubing to fit? It would be smooth the parts and equipment is already there and you could make different sizes 2.5" to 4.0". any one tried that yet?
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
Re: snorkel
« Reply #9 on: December 21, 2004, 08:51:41 AM »
Make friends with an electrician they have a heat box that thay use to shape plastic conduit for underground work it will shape ABS. or make your own with sheet metal and you BBQ.
Thanks
Wayne
Clearly a road
Offline zukizzy
  • 123
Re: snorkel
« Reply #10 on: December 21, 2004, 08:57:11 AM »
Yes it works but you have to use abs as filler. plastic is like metal hard to mix different plastics but some will stick to others. try a small bit of it with your soldering iron or should I say someone elses soldering iron. it works.
Thanks
Wayne
Clearly a road
Offline mahimahimo
  • 377
Re: snorkel
« Reply #11 on: December 21, 2004, 08:57:18 AM »
so pics any one?
Offline 1bigtracker
  • 3409
Re: snorkel
« Reply #12 on: December 22, 2004, 02:39:21 AM »
well i think after everything started to add up when building one it might not be as cheap.  new filter if the snorkle dosn't go into factory air box, hose clamps, plastic, brackets, rubber cuplers, ect...  after you add all those charges up it wouldn't be so cheap. :-/
stu
Re: snorkel
« Reply #13 on: December 22, 2004, 02:41:27 AM »
So are you wimping out of the challenge allready ???
« Last Edit: December 22, 2004, 02:41:54 AM by wildgoody »
Offline 1bigtracker
  • 3409
Re: snorkel
« Reply #14 on: December 22, 2004, 02:44:31 AM »
cheap and effective, not as good as a RRO one but works ok.  cost 0 dollors,  beat that! :P ;D
EDIT:  5 dollors in silicone!  lol
stu
« Last Edit: December 22, 2004, 02:45:16 AM by 1bigtracker »
  ÂÂÂÂÂÂÂ
