update: distributor shaft extension housing (remounted for now)
  • 18 Replies
  • 5095 Views
Offline daddyizzle
  • 728
  • Colorado is still my home!!
When I replaced my o-ring a few months back, I noticed the bottom bolt was stripped. Not holding it tight so it still leaks.
1. Would I be able to tap the hole out with out removing the whole component?
2. If not, could I remove the housing with the distributor intact and do the job without having trouble with the gear on the distributor moving on me?
3. What would be the best tap size to go up to or is their a better way to do this?
I'm kind of pressed for time lately so I want to do it the best way, and hopefully the quickest/easiest way as I hate to pull the distributor and have to go through the trouble of finding the right spot to put it back in. Seems I always miss by one tooth either way.
-Adam
« Last Edit: March 17, 2007, 03:34:12 PM by daddyizzle »
Offline ROSS
  • 1412
Re: distributor shaft extension housing o-ring.
« Reply #1 on: March 10, 2007, 12:14:38 PM »
remove the dist. make note where its pointing. then the housing, then use a hela-coil.
you can get them at any auto parts store
Offline daddyizzle
  • 728
« Reply #2 on: March 10, 2007, 02:58:59 PM »
Darn! I guess there isn't a way to do it without removing both? Maybe not enough clearance anyways , but what is a hela-coil?.
-Adam
Offline ROSS
  • 1412
« Reply #3 on: March 10, 2007, 03:22:22 PM »
its a metal sleeve that is threaded inside and outside.
ask for it like at napa or checker whatever they'll know what you meen.
they come in a kit with the tap and inserting tool and threadlocker.
by fixijng it this way you can use the standard bolt.
take the bolt with you to make sure you get the right hela-coil
Offline daddyizzle
  • 728
« Reply #4 on: March 10, 2007, 04:04:00 PM »
Thanks! I'll do one better. I'll take one of the good bolts in case the one that doesn't work is a wrong bolt. It seems to me that they should be all the same size and thread count but different lengths. I wonder if maybe someone in the past mixed the bolts around. I think one even has a different size head. Maybe they lost one and put in an S.A.E. by mistake. I'll certainly take a closer look at the bolts and holes to see what exactly happened so I can fix it right this time.
What size are they supposed to be, and which length bolts go in which holes?
-Adam
Offline ROSS
  • 1412
« Reply #5 on: March 10, 2007, 04:08:14 PM »
I'd have to go pull mine out to find out.
getting old. have a bad case of CRS  ( CAN'T REMEMBER SHIT)
« Reply #6 on: March 10, 2007, 04:09:29 PM »
I think you mean heli-coil? If they're the bolts I'm thinking of then they're M6 x 1.0. Theres another company that makes the inserts under the brand name recoil
« Last Edit: March 10, 2007, 04:13:25 PM by Rhinoman »
Offline daddyizzle
  • 728
« Reply #7 on: March 10, 2007, 05:00:33 PM »
Same lengths. I thought two were one size and one was different.
-Adam
Offline ROSS
  • 1412
« Reply #8 on: March 10, 2007, 05:32:14 PM »
I said I was getting old. affects my spelling
Offline daddyizzle
  • 728
I went and picked up the helicoil set as suggested here. Expensive! Anyways, I lifted up the hood and see a lack of clearance behind the head.
1.  How would one go about drilling out the hole on the back of the head
2.Would a right angle drill or maybe a  Dremmel with a right angle fit in there or do I have to pull the engine or pull the head?
3. What would be the best way to get it done without taking too much time?
-Adam
Offline ROSS
  • 1412
see if you can fit a right angle drill in there.  pulling the motor is easy and quick. that way you can see what your doing real well. and get it done right the first time.
Offline daddyizzle
  • 728
I got some stuff while waiting for a reply:
Kobalt right angle air drill: about 50 or 60 bucks with tax.
Napa helicoil set with 10 inserts: about 40 bucks with tax
I would pull the engine but times tight and so is my back. I think I can either use a stubby bit or cut the one I bought and get in there. My concern is getting metal shavings inside the head. I'm not sure if it's a through hole but I'll check, and use a stop collar if I have to.
Wonder what a shop would have charged to do this? Oh well, I will attempt to tackle this hopefully small project Saturday morning. Thanks for the help.
-Adam
Offline daddyizzle
  • 728
Re: update: distributor shaft extension housing (remounted for now)
« Reply #12 on: March 17, 2007, 03:54:21 PM »
I think I got it fixed. As it turns out, the top two bolts were stripped. One of them had the threads from the head right with it. There also was evidence of some kind of J.B.Weld or something for thread repair.
A couple months, back maybe 6?,  I had taken the housing off to replace the o ring and noticed there wasn't one in there. I suspect someone tried tightening the crap out of it to stop the leak. I could feel the threads stripped a bit then but hoped with a new o ring that it would stop the leak. It did temporarily but got worse over the months. I was losing a quart every two weeks I think.
Now back to the repair. If I could do it all over again, I would find 1/2 inch longer bolts then what was in there and try retapping and tightening down. If that didn't work, using the helicoil with a longer insert. say close to an inch. I believe the hole will accommodate it. Then I would take bolts that would run just short of the flange in the helicoil. Otherwise you bottom out and hit it. Then you strip the bolt out trying to tighten it up.
The problem I ran into with doing this job with the engine installed is:
1. I had to use the Kobalt air drill and lob off the drill bit and stick it deep inside of the drill chuck, then carefully sneak it behind the head.
2. I then had to pull the bit out of the chuck to drill a little deeper.
3. The tool they give you to install it didn't work right, I had to take the bit out of the guide and turn the coil in with a tight grip from both hands and finish with a small wrench.
4. There was no way that I could see to get a punch and knock out the flange inside the helicoil once it was installed.
The biggest obstacle I came across was the lack of clearance. It would have also helped to have a few long m6-1 bolts and nuts. I ground mine down to size until I could get them to work. All because I couldn't knock the flange out.
I think this will work for now. I may have jacked up the mount holes in the head though as I am afraid to ever take it off again. I'll be watching for a high performance head in the future. Next time it leaks, the whole heads coming off just to be safe.
I just had to make sure I had it back and  running before the work week, and for a minute, I thought I was screwed.
Anyways, I think it will work for now.
Comments welcome.
-Adam
'taeb ht e  1 intrkabs
« Reply #13 on: March 18, 2007, 08:23:42 AM »
Glad you got it sorted.  The Recoil kit doesn't use a guide just the inner part, as long as the insert screwed in OK then its not an issue. Helicoils are standard fitment for aluminium used in aerospace applications, standard' length is 1.5-2 x the diameter which is plenty strong enough. If you ever take the head off you can knock the tanf off but I doubt that you'll have any more problems with those threads now.
Offline daddyizzle
  • 728
« Reply #14 on: March 20, 2007, 01:57:52 PM »
3 days later and no leak whatsoever (yet) I'll keep my fingers crossed. Now thinking about a lift....
-Adam
