will an 89 tracker motor fit in a 94 tracker?
  • 12 Replies
  • 4490 Views
Offline westvilleguy
  • 53
« on: March 10, 2007, 02:25:28 PM »
i got an 89 for parts was gonna put the motor in my 94 i just picked up they look the same except i thought the valve covers might have been different i could be wrong but i left the 94 at my parents so cant really compare them right now
« Last Edit: March 10, 2007, 02:40:05 PM by westvilleguy »
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Offline museboy07
  • 641
Re: will an 89 tracker motor fit in a 94 tracker?
« Reply #1 on: March 10, 2007, 03:21:18 PM »
actually i put an 89 motor in my 94 just like you wanna do...it'll work...both are exactly the same
  • 53
« Reply #2 on: March 10, 2007, 03:50:42 PM »
ok i figured it was cause its the same as my 93 and 91 but just wanted to make sure
Offline museboy07
  • 641
« Reply #3 on: March 10, 2007, 04:06:23 PM »
yup yup..good luck with the swap
Offline kirknd4spd
  • 333
« Reply #4 on: March 10, 2007, 10:17:19 PM »
yes, if your 94 has an 8v. but if your 94 has a 16v engine, you would be losing about 15 horsepower......that is, of course, as long as the 89 has a 1.6.....some had a carbuerated 1.3, which would almost be pointless to swap into your 94
  • 53
« Reply #5 on: March 11, 2007, 09:26:19 AM »
the 89 is a 1.6 how would i tell if the 94 is a 16v i've only owned 8v's and would it still be a direct swap with the 8 in place of the 16?
« Reply #6 on: March 11, 2007, 09:31:59 AM »
16V has 16V cast on the rocker cover. The cover itself is quite different, if it looks like an 8V then it is one. 16V wiring and electronics is quite diffferent, not a straight swap. A 1.3 would have G13a on the block.
  • 53
« Reply #7 on: March 11, 2007, 11:03:19 AM »
i cant remember if the cover is the same its in town at my old mans. i know the throttle body and some of the wiring was the same just trying to figure it out before i go out and tear the motor out of the 89 is there any way to tell by the vin number or where could i find a pic of the 16v
  • 53
« Reply #8 on: March 11, 2007, 11:15:20 AM »
i did a search on carfax just where u put in the vin and it tells u what the car is  but u have to pay to find out the history and this says its a- 1.6l L4 FI does mean its 8 or 16 lol
Offline kirknd4spd
  • 333
« Reply #9 on: March 12, 2007, 10:23:02 PM »
« Reply #10 on: March 12, 2007, 10:26:49 PM »
yeah, but the 8V has better low end power, so better for wheeling :)
« Reply #11 on: March 13, 2007, 06:04:34 AM »
The only dyno comparison that I have seen for both showed the 8V and 16V equal at lower rpm with the 16V just building harder. At high rpm the 16V just carried on increasing power after the 8V had started to drop off.
  • 53
« Reply #12 on: March 13, 2007, 07:58:37 AM »
got the tracker home the other day the motors are the same jsut gotta figure out what i can keep on the 89 when i drop it in the 94 i heard there was some stuff that is different on them
