What will fit this
  • 2120 Views
Offline mbmarkyb
  • 461
    • UK Vitara
What will fit this
« on: December 29, 2004, 10:04:31 PM »
Lots of talk on axles at the moment and i have a question.
Been looking around for possible front axles to use.
I do need to measure my crown ring but am i right in thinking it is 8.8"s on the 10 bolt. on 5.12
Ideally I would like to find an axle that can take my kick/vitara front diff and fit it to the casing and 3rd member housing.
I see that Dana 30 or 35 is close also the 50 but im unsure has anyone got specs or know what will take this.
Im trying to do a live axle converstion on a budget (as normall) leaving my rear setup in place as i have upped this a lot to gain travel etc... im after a reliable axle rather than 40 inches of travel.
reason for staying with the stock vitara diff is i have an ARB that i want to use. the arb is 26 spline which i can have shafts made to fit.
Also i am based in the UK so the F150 that seems to be a good match are rare as rocking horse pooh over here.
Any help in my 2005 project that i need to complete by mid feb will be great cheers
Markyb (UK)
UK Vitara JLX SE
mudfkr
Re: What will fit this
« Reply #1 on: December 30, 2004, 05:58:22 AM »
Well you didn't say how bigger budget you had !!
but I like this option  :P
Spidertrax Sidewinder Open Knuckle Front Axle $1699.95
All the details here are here:
http://www.spidertrax.com/drivetrain_sdw.htm
« Reply #2 on: December 30, 2004, 06:10:29 AM »
or just run a samurai front end with spacers,and some axels from roadless gear or trail tough(they both carry the same now)that would be cheaper.
