HELP.....PLEASE
  • 2475 Views
Swifgriff
HELP.....PLEASE
« on: March 12, 2007, 04:42:26 PM »
I have a problem and its called an 87 Samurai. When i bought this it was used for off road.
I took the lift kit and big tires off and put stock springs and tires back on it and now use it for street driving only. The trouble is sometimes it acts like its running out of gas. It has a weber carb on it. When i first got this it had a Ele. fuel pump, with the stock fuel pump rod taken out so it would not work. I had a lot of problems with it then running right. I bought a rod and put
it in. It ran great for about 10 or 12 weeks. Now its back to acting like running out of gas again.....BUT not all the time..I have the Ele fuel pump and the stock fuel pump working at the same time and still have this problem...I have cleaned the carb. out....no help
I THANK YOU IN ADVANCE FOR ANY HELP ANYONE GIVES.........Swifgriff
Offline istone100
  • 18
Re: HELP.....PLEASE
« Reply #1 on: March 12, 2007, 04:46:13 PM »
fuel filter ????
I know when these clog  it can seem like your running out of gas (at least thats what happened in my toyota)
Swifgriff
Re: HELP.....PLEASE
« Reply #2 on: March 12, 2007, 05:58:41 PM »
I forgot to tell you ...i  already put a new one in..and took the gas tank off and made sure it was clean.............Thanks
Offline ROSS
  • 1412
Re: HELP.....PLEASE
« Reply #3 on: March 12, 2007, 06:14:03 PM »
how about the float level??  when I had a weber mine did that.
raised the float level worked great after that. then I took it off and put EFI on.
Swifgriff
Re: HELP.....PLEASE
« Reply #4 on: March 13, 2007, 02:40:15 PM »
I raised the float level a little bit the second time it messed up. Worked fine for awhile.
What i don't understand is why it only runs like this at times ??? and other times it fine.
...........Thanks
phloop
Re: HELP.....PLEASE
« Reply #5 on: March 13, 2007, 04:35:37 PM »
The problem is the fact you took a nice wheelin' rig and lopped it's nards off. :o
It is fighting back. ;D
Try replacing the stock fuel pump. If it ran "great" for awhile after you replaced the fuel pump push rod and then started running crappy, it might be the fuel pump starting to give up the ghost.
And that Webber might be having fit's itself.
« Last Edit: March 13, 2007, 04:37:39 PM by phloop »
Offline locjaw
  • 2045
  • 22
Re: HELP.....PLEASE
« Reply #6 on: March 13, 2007, 05:15:49 PM »
ROTFLMFAO
jason
Swifgriff
Re: HELP.....PLEASE
« Reply #7 on: March 13, 2007, 08:00:39 PM »
The stock pump may be going bad, but it would run good at times with just the ele. pump.
I just finished raising the float level as high as it would go and also by pasted the canister.
Drove it down the road and back and so far so good...Swifgriff
Offline ROSS
  • 1412
Re: HELP.....PLEASE
« Reply #8 on: March 13, 2007, 08:04:38 PM »
nice looking rig.  hope it keeps running good for you
