sidekick to vitara diff gears
  • 3545 Views
Offline toofaroffroad
  • 226
« on: March 13, 2007, 10:59:55 PM »
Has anyone installed 5:13 sidekick diff gears into 2.0 ltr vitara diffs? Is itworth the work if your running 31's. I have sidekick diff gears but wonder if it's worth it.
Offline bzzr2
  • 1011
Re: sidekick to vitara diff gears
« Reply #1 on: March 14, 2007, 05:04:30 AM »
i think ZR2 did this in his 2002 tracker.
09 taco reg cab short box 4x4
Offline lowrezolution
  • 292
  • "Get bent!"
« Reply #2 on: March 14, 2007, 06:20:28 AM »
I'm trying to go the other way, I want to put my 5.125's from my '01 into diffs from a '91 so I can spool the rear, loose the "shit-on-the-fly" and locker the front.
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline ZR2
  • 103
  • Powered by SUZUKI
    • See the best sidekick/tracker/vitara website!!!
« Reply #3 on: March 14, 2007, 05:39:19 PM »
yes, i have the rear sidekick 3rd member with 5.13 and i have the front ring and pinion 5.13 gear on front!
  • 226
« Reply #4 on: March 14, 2007, 10:17:36 PM »
so ZR2, is this gear switch worth it for 31's. I've already got the gears taken out of my 1994 sidekick. What do you think?
  • 292
  • "Get bent!"
« Reply #5 on: March 15, 2007, 06:30:47 AM »
Just to clarify. you are running the ring and pinions from you '99-05 in the diffs from a '98 and older?
I'm a little s...l...o...w today  :P , I just want to be sure.
Thanks
Scotty
2001 Tracker LWB
  • 226
« Reply #6 on: March 15, 2007, 02:46:42 PM »
right now i'm running stock 1999 chev tracker diff gears. I'm pretty sure they are 4.88
I want to install the 5.13 diff gears out of my 1994 sidekick.
I also heard that the 1991 4-door kick has 5.32 gears, but i'm sure that would be hard to track down.
« Reply #7 on: March 16, 2007, 08:40:55 AM »
I'm running 12-bolt 96'-98'  Kick rear R&P (with ARB) in my 2000 GV.  In the front, I'm running auto XL7 R&P on a Sammy rear diff carrier in a steel GV housing.
The XL7 R&P fit correctly without having to space over the carrier (spacing is similar of what you do with Kick gears in a Sammy).
I'm running 31's and an auto tranny.   Yes, without the 5.12's it would be a slug.
