front 4x4 wont work
  • 9 Replies
  • 2514 Views
Offline Grizzqc
  • 24
front 4x4 wont work
« on: March 20, 2007, 05:48:05 PM »
Ok it shifts fine on shifter 2h truck moves 4hi truck moves only rear wheels neutral truck does not move 4 low truck moves only rear wheels.Front drive shaft is turning but front drives are not even with hubs locked what should I check first before ripping it all aprt?Any info would be great as I am a newbie :-[ :-[ :-[ simplest things first please :-[ :-[
Offline balance
  • GO COLTS!
    • www.gotmudd.com
Re: front 4x4 wont work
« Reply #1 on: March 20, 2007, 05:49:52 PM »
i would check the shift linkage. its a start
91 Sidekick
2" spring spacer lift
29" Superswampers TSL
More to come...................
http://www.youtube.com/user/GotmuddHaspin
Offline Element
  • 1902
  • LillyKicker
« Reply #2 on: March 20, 2007, 05:52:35 PM »
What vehicle are you running? Have ya had it for awhile? When did it start?
zUkTAH
U4WDA
Offline GmManDan
« Reply #3 on: March 20, 2007, 05:54:17 PM »
I would just pull the hub off and make sure it has grease in it make sure its not rusted up. It happened to me when I bought my sammy. A quick cheap fix it is only like 6 bolts.
1999 Gmc sierra 4x4 5.3
1987 Suzuki samauri ,soft top, 5 inch spoa, 3 inch body ,31 tsl radials ,1.6 Efi swap in prgoress.
Offline ROSS
  • 1412
« Reply #4 on: March 20, 2007, 05:57:28 PM »
its not the linkage if the front driveline is spinning.  check the hubs.  if you pull the hubs off you can see the end of the axles . see if there turning. if yes fix hubs. no fix spider gears or lockers
« Last Edit: March 20, 2007, 06:02:46 PM by ROSS »
Offline Grizzqc
  • 24
« Reply #5 on: March 20, 2007, 06:31:52 PM »
just got truck it has been sitting for over a year.It is a 91 tracker two door if I new how to put a picture I would lol
http://new.photos.yahoo.com/grizzqc/album/576460762394437738
« Last Edit: March 21, 2007, 05:57:08 AM by Grizzqc »
Offline GmManDan
« Reply #6 on: March 21, 2007, 02:36:47 AM »
If it were me I would say hubs needed to be lubed or I would at least start from their.
Offline stock93tracker
  • 309
« Reply #7 on: March 21, 2007, 10:36:50 AM »
yup, the hubs may need redone.. One of the ones I got was junked up and wouldnt engage, Im just gonna rebuild it.
93 Geo Tracker
-2" Lift
ozziel
« Reply #8 on: March 21, 2007, 04:25:27 PM »
Yup. I would also guess hubs.
If you need a set send me a message, I'm sure I have some spares around here somewhere.
Montreal area.
Offline Grizzqc
  • 24
« Reply #9 on: March 22, 2007, 06:01:26 AM »
thanks ozz
