Sammy questions
  • 2364 Views
Offline mbmarkyb
  • 461
    • UK Vitara
Sammy questions
« on: December 23, 2004, 05:55:04 PM »
Hi,  I wanted to get some information on the sammy front axle if I may.
Anybody running 33" tyres or bigger
1, If any what breakages do you have?
2, how long do the bearings/burfields last
After my kick/vitara goes through bearings and front drive line components a lot i am looking to convert the front to live axle on coils.
I am limited as I have an  ARB that will fit into a front sammy axle so i will be leaving my stock rear axle in place. as normall its low budget so i need to use whats around to keep the cost down
Any information will be great before i dive into this conversation
Markyb (UK)
UK Vitara JLX SE
Offline Real_Red_Sammi
  • 43
  • Make it hurt!
Re: Sammy questions
« Reply #1 on: December 24, 2004, 09:20:00 AM »
       I'm running 35's on my sammi and no breakage yet, and so far I've been Making It Hert for a little over 6 months. I believe that with 33's everything will work out fine, it's nice when people see the ways of the solid axle ;D. All the bearing and stuff are fine, birfields are fine, but it also matters your tires, For 35's my tires (Dunlop Mud Rovers) are pretty light!
    Make It Hert!!!!
"I do what I want"
LMS wasted my time
Re: Sammy questions
« Reply #2 on: December 24, 2004, 09:36:35 AM »
I run an 88 samurai with a sixteen valve and 4 to 1 low range with 33" type mud tires like a bfg mt, and so do a couple of friends of mine. no probs so far, you have to be careful about stuffing the tire into your fender or getting on it while haveing the wheel turned sharp to one side, other than that no probs yet! oh ya my friends have only broken two front axels in three years or more of heavy off roading.
Offline cuban_b
  • 38
  • shop smart, shop S-mart
Re: Sammy questions
« Reply #3 on: December 26, 2004, 07:33:38 PM »
Sami axles can live with 33s. If you have open diffs.  If you're locked up, it's only a matter of time before they break. I know.
Risk it anyway, it will give you a reason to get toy axles
Re: Sammy questions
« Reply #4 on: December 27, 2004, 05:00:22 AM »
I will prob. get the axels from roadless gear be for I go to toys, I have too much money into mine to change them, plus I like the light weight of the samurai for snow, gas mileage,and for driving the speed limit with out being floored all of the time. and my other rigs have the same five lug pattern wheels.
Offline mesjr2004
  • 422
Re: Sammy questions
« Reply #5 on: December 27, 2004, 12:30:29 PM »
im running 31'' claws and a locker and ive broken about 6 birfields ,and twisted 2 calminy "HD" axel shafts in half. went back to stock axel shafts and trailtough birfield rings.havent broken anything else yet,but only ben wheeling twice since. you couldint pay me to go w/bigger tires. oh i carry rite and left axles now when i wheel ;)
Offline mbmarkyb
  • 461
    • UK Vitara
Re: Sammy questions
« Reply #6 on: December 28, 2004, 05:30:56 AM »
cheers for all the responses.
I think the sammy axle is stronger than the stock tracker setup so im doing a converstion over the next 2 months will post back.
things i have to help in strength is a 26 spline ARB and 26 spline shafts , I will use my callipers discs and i need to measure up what shocks springs to use.  I will be leaving my calmini rear setup in place so not looking for lots of travel on the front just a reliable axle with simular travel to the rear standard calmini 3 inch setup.
Markyb (UK)
UK Vitara JLX SE
