my RTI
  • 12 Replies
  • 3836 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
my RTI
« on: March 25, 2007, 08:10:54 AM »
i was just wondering what you guys think i scored?
stock wheel base.
20 degree ramp.
i was thinking, after i had looked at the pics, that i may have been able to go a little more, as my tyres were not off the ground yet. i had to do the ramp in 2WD only, as i have broken a right hand side AXLE, not CV joint.
so i guess when i'm fixed, i should do it again and see how much higher i can go up.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: my RTI
« Reply #1 on: March 25, 2007, 08:18:50 AM »
ah the rig I kinda used as a model for mine.....  man that thing has gotten dented up since Ive seen it!  8)
ya looks like you could get up that ramp alittle more...  not bad there tho...
Offline SiKiD_01
  • 574
Re: my RTI
« Reply #2 on: March 25, 2007, 08:23:16 AM »
yeah, its looking pretty sad these days.
every year, we get a shite load of rain up my way, and trying to stay on the track and away from the trees on the trial proves very hard. especially when you need to do a 6 point turn on a tiny trail to go back and recover someone else.
other than that, my vit's doing pretty good for itself. it still sorta together (only just).
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
Re: my RTI
« Reply #3 on: March 25, 2007, 09:05:29 PM »
Dont know what type of RTI score the Jeep would get.  Got a little more flex than in the pics.  And the Tracker don't do all that bad.  I was pleasantly surprised.
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
ozziel
Re: my RTI
« Reply #4 on: March 25, 2007, 09:09:35 PM »
stock wheel base.
20 degree ramp.
Frontwards 700-750
Backwards 750-800
Just a guess though. ;D
Oz
Offline SiKiD_01
  • 574
Re: my RTI
« Reply #5 on: March 26, 2007, 01:16:26 AM »
if i had solid axles i would get more, but i still have IFS. which isn't that bad.
910 forwards
940 backwards
Offline biker
  • 730
  • It's a sickness I tell ya
Re: my RTI
« Reply #6 on: March 26, 2007, 07:08:23 AM »
That's pretty darn good for IFS, what have you done to your susp?
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline BigPig
  • 276
Re: my RTI
« Reply #7 on: March 26, 2007, 12:52:28 PM »
You get zero all the way around because you were using the wrong side of the Vit.   ;D
'89 Sidekick w/ 4.5" of lift.
Offline poorboy
  • 29
  • When in doubt... beat it out
Re: my RTI
« Reply #8 on: March 26, 2007, 01:23:46 PM »
lets see if i can post this...
i think i got it.  i
it says on here that on 20 degree ramps that you take (wheel base) x (.342) = total articulation
i think that you should score somewhere around 1080? is that right or am i reading that wrong?
im probably completely wrong and if i am im sorry then.
its supposed to be for a samurai
That sh*t'll be alright
Offline poorboy
  • 29
Re: my RTI
« Reply #9 on: March 26, 2007, 01:25:55 PM »
tracker kick wheel base is 86.6 isn't it?
Offline SiKiD_01
  • 574
Re: my RTI
« Reply #10 on: March 27, 2007, 01:56:31 AM »
we score positve, and you guys score negative.  ;D ;D ;D ;D
Offline SiKiD_01
  • 574
Re: my RTI
« Reply #11 on: March 27, 2007, 02:00:00 AM »
"stock"
well, i didn't do the measurements, but i've tried my best to convert the measurements so that you guys can under'ma'stand what i'm going on about.
ok, forwards, i drove about 79.4" up the ramp
and reverse i drove about 83.1" up the ramp
and maybe with a little more to go til my back tyre lifts off the ground.
see what you guys come up with.
Re: my RTI
« Reply #12 on: March 27, 2007, 05:01:24 AM »
I was guesing around 900. Looks good Skid  8)
