SOME RUST
  • 2246 Views
Offline Eden1
  • 73
SOME RUST
« on: March 25, 2007, 07:14:18 PM »
i HAVE SOME RUST HOLES IN THE BOX OF MY TRACKER.jUST OVER THE WHEELWELLS UNDER THE BOLTS FOR THE SEATBELTS.cAN ANY ONE TELL ME A QUIK AND LASTING FIX FOR THIS.i WAS THINKING RUST INHIBITOR AND SOME THICK BOXLINER COATING???
Offline BigPig
  • 276
Re: SOME RUST
« Reply #1 on: March 26, 2007, 07:17:38 AM »
I've heard of people using rust inhibitor and then covering the hole with duct tape followed by a thick layer of bed liner material.  However, if it's anywhere near the seatbelt bolts I would recommend an all-steel repair since a life could depend on it.  HTH.
'89 Sidekick w/ 4.5" of lift.
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: SOME RUST
« Reply #2 on: March 26, 2007, 09:39:02 AM »
I would definitley cut out all the body rot and weld new material in. You can buy nuts and weld those back in for the seat belts, at least that's what I did.
I have my kids riding back there so I wanted everything good and strong.
Jim
Offline BigPig
  • 276
Re: SOME RUST
« Reply #3 on: March 26, 2007, 12:49:20 PM »
You can buy nuts
   :o
I know a couple of guys who should 'cause they lost theirs to their wives.  ;)
Offline Eden1
  • 73
Re: SOME RUST
« Reply #4 on: March 26, 2007, 06:36:51 PM »
I have no rust even close to the seat belt holes.It was all on the bed right under them.So I cut out the rust put some sheet metal down and riveted the metal down.Then I caked the s--t out of it inside and out with some black tar under coating.I also used the rust inhibitor.
