idler arm removal
  • 1390 Views
idler arm removal
« on: March 26, 2007, 07:34:18 AM »
 ??? speaking of idler arms, yesterday I got a wild hair, and decided to strenghen the idler arm mount and build a lower support for it as well. (This is for the Tracker.) I removed the mount and boxed it in with steel plates in the open areas to strengthen it, then made up a lower support bracket that bolts to the A arm mount and connects to the bottom of the idler pivot, similar to a Calmini support.  All was well there, But when I tried to remove the idler arm itself I couldn't budge the thing. I tried a couple of pullers but really couldn't get a good bite under it. I've lubricated it with some kroil ( serious penetrant) and hope to take another crack at it later. I want get it off so I can maybe make up a stronger one, or strengthen this one. Any tips on tools or tricks to gettin' it off?
Offline BigPig
  • 276
Re: idler arm removal
« Reply #1 on: March 26, 2007, 12:57:16 PM »
Did you ask it nicely to just come on off of there? ;)
If nothing else you can try heating it with your torch.
'89 Sidekick w/ 4.5" of lift.
« Reply #2 on: March 26, 2007, 01:22:10 PM »
 ;) I asked it, not very nicley I'm afraid! I will give it some heat and see if that helps. Thanks BigPig.
