What cams u got in ur 8 vlave and thoughts?
  • 20 Replies
  • 4689 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: December 21, 2004, 03:29:34 PM »
WOndering what u guys got in ur 8 vlave im looking for a cam and wondering which to get more highway power.
01 GRAND VITARA
Re: What cams u got in ur 8 vlave and thoughts?
« Reply #1 on: December 21, 2004, 03:47:02 PM »
Custom Grind, Engle Cams
Santa Monica Ca.
Slight more lift and duration, I don't remember
the specs, but I asked for a smog compliant cam
Offline 1bigtracker
  • 3409
« Reply #2 on: December 22, 2004, 02:34:12 AM »
anyone got a calmini or an Isky?
stu
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: December 22, 2004, 03:28:57 AM »
Check out reynoldsmachine.com they have heads withall the trick work. I'm looking at there stage III for $659.39. ;D ;D ;D
   Kevin
Offline chet
  • 556
  • Zuki time!
« Reply #4 on: December 22, 2004, 03:29:18 AM »
or a hawk cam? I would like to know how they perform as well? I would guess cam and header should make a noticable increase in power for the 8V?
« Reply #5 on: December 22, 2004, 03:37:49 AM »
Stock ;D
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #6 on: December 22, 2004, 07:22:37 AM »
stu
I just bought ( but have not received yet ) a rebuilt head with a Calmini cam. Once it's installed I'll let you know what I think.
It's going on/in the engine after I receive the Weber 32/36 DGAV I bought from a guy in the US, he sent it to MidWest Performance ( Sarge ) who is going to set it up for bolting it on my Sammi with one of his flowed intakes. I also bought headers, so all the changes at once will make  difference I hope  ;)
[edit]Well, that plan changed a bit since I bought the Camden SuperCharger 2days ago ;), but I will still use that head with the Calmini cam, shave the head just a little, I just have to take in all the advise I can find on the Internet and all the advice from people "in the know" to make my final plan [/edit]
« Last Edit: December 25, 2004, 09:15:03 PM by nitromax »
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline jerryp58
  • 449
« Reply #7 on: December 22, 2004, 08:43:45 AM »
Stock ;D
Same here  :)
Jerry
Offline szabotage
  • 114
  • snaggletooth
« Reply #8 on: December 22, 2004, 09:26:02 AM »
did the isky cam in the 1.6 8V and noticed nothing.
did the isky in a 1.6 w/1.3 head and pony carb, very torquey between 2200-3500 rpm, lots of pull
driven a 1.3 with the isky and dt header and noticed a big improvement torque in a wider rpm range
my conclusion, not worth it for the 1.6 8V. try this guy he's in BC so it'll be a bit cheaper for ya
http://www.coltcams.com/index.html
Offline JDMCRX
  • 1110
« Reply #9 on: December 22, 2004, 11:34:17 AM »
Yeah im thinking of getting the HAWK cam and shave the head .20thou.
And hope to see some gains. Cause motor swap is not in my option.
01 GRAND VITARA
Offline HUMZUKI
  • 117
  • Fool!
« Reply #10 on: December 23, 2004, 12:46:12 AM »
   Kevin
Thats like $160 more than a Summo II and aside from a new rocker shaft, It's about the same thing.
Offline JDMCRX
  • 1110
« Reply #11 on: December 25, 2004, 11:17:21 AM »
Anyone what u guys think about the HAWK cam?
01 GRAND VITARA
Offline 1bigtracker
  • 3409
« Reply #12 on: December 25, 2004, 12:41:21 PM »
Stock ;D
yea me too >:( >:( >:(
stu
Offline JDMCRX
  • 1110
« Reply #13 on: December 25, 2004, 01:03:31 PM »
im thinking of taking the head off shave it .20th and changing the valve stem seals and putting the cam and some slight port work. Hawk cam
01 GRAND VITARA
« Reply #14 on: December 25, 2004, 04:14:49 PM »
for that kind of money just get a used 16 valve and be done with it!
