sidekick problems
  • 2320 Views
Offline zukigroundpounder
  • 80
  • 3 trackers/kicks, 1 eclipse.
sidekick problems
« on: March 29, 2007, 11:56:52 AM »
I got a side kick that had an 8 valve motor in it an i changed it too a 16 valve motor.Now after the change the cluch dont disengage,I used the presure plate and fly wheel from the 16 motor Is there any difference in the presure plates?Any help will be appreciated..
thanx..
Drive it like you stole it.
Offline RHodge
  • 523
Re: sidekick problems
« Reply #1 on: March 29, 2007, 02:30:46 PM »
the part #s looks to be the same for both 8v and 16v clutches
looked them up |removethispart|@ work
are you sure you got the disk in wright I'v seen them put in backwards and do what you are saying
Ryan
« Reply #2 on: March 29, 2007, 05:44:00 PM »
The pressure plates and flywheels are the same between the 8V's and the 16V's.  The only difference is the 16V fiber/friction plate is bigger diameter...I assume because of the higher HP of the 16V engine.  But you can mix/match any of the fiber/friction plates/pressure plates and they will all work fine.
As mentioned, I would make sure you put the friction plate in the right way.
  • 80
« Reply #3 on: March 30, 2007, 06:20:07 AM »
hello
i got it a part last night and the throw out bearing and pressure plate are gone. the throw out bearing went through  the pressure plate i  think the clutch disc was in wrong.which way do the springs on the disc go toward the flywheel or the pressure plate?
thanks.
« Reply #4 on: March 30, 2007, 07:30:33 AM »
hello
thanks.
You can see springs on both sides of the clutch disc, so I'm not really sure what you are asking there.
IIRC, the clutch disc will only go one one way AND fit flush up to the flywheel...if you install it reversed, I thought the center splined part of the clutch disc would hit the flywheel before the fiber/clutch part of it would fit flush against the flywheel.  In other words...the side of the clutch plate/disc that has nothing sticking out beyond the fiber part of it, goes against the flywheel.  Hope that makes sense.
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
« Reply #5 on: March 30, 2007, 12:02:58 PM »
It should say on the disk flywheel side, with all the clutches i have replaced they have always said flywheel side towards the center of the disk.
  • 80
« Reply #6 on: March 31, 2007, 06:02:23 AM »
hello
i went yesturday and got a clutch kit everything new and installed it myself and it works fine now.  the clutch disc was in backward when i got it the sidekick that was the guys problem he thought it was the cable out of adjustment. but anyways its working fine and now its time  to hit the woods.thanks to all for the help.
thanks.
