Lockers
  • 1927 Views
Offline Armour
  • 360
Lockers
« on: March 29, 2007, 06:08:43 PM »
Is there any advantage or disadvantage to running a lockright with or without couplers. I know with couplers is noisy but are there any problems running the one without couplers. Any input would be great. I am new to this stuff.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Lockers
« Reply #1 on: March 29, 2007, 07:13:23 PM »
The couplers are what make the unit unlock under heavy load.  Removing them, if I understand you correctly, will effectively disconnect the ring gear from the axle shafts thus removing all drive to the wheels.  That "popping" sound you hear when in a turn is the LockRight telling you that it has reached maximum torsional stress and has briefly unlocked.  When unklocking occurs, it becomes easier to drive in a turn as opposed to a straight line.  This feature lets the LockRight (and variants) sort of (!) act like a cross between an open differential and a locked differential.
Hope this helps!
Ack
Re: Lockers
« Reply #2 on: March 29, 2007, 09:46:04 PM »
I think he means when you buy them with or without couplers, most buy them without because if you bend a housing they will slip, they have a more square of a tooth and a finer one at that, the stock side gears work just great and it is the cheaper of the two.
Offline Armour
  • 360
Re: Lockers
« Reply #3 on: April 01, 2007, 06:19:24 PM »
That is exactly what I meant. I don't mind spending the extra it they work better with couplers. If there is no real advantage then I will buy the kit without.
