K&N Filter and intake
  • 10 Replies
  • 2726 Views
txzuki07
« on: December 25, 2004, 03:09:52 PM »
Okay I collect some money some how and manage to get a Dynamax cat-back exhaust system and hope to get the K&N fiter and intake. My qustion is is it worth the money in terms of performance. Any help would be aprciated.
Joe
Re: K&N Filter and intake
« Reply #1 on: December 25, 2004, 04:18:27 PM »
You might want to put what kind of rig and engine, tires ect. carb or f.i. ? trans type? what you use it for?
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: December 26, 2004, 01:25:56 AM »
I'm not sure about the performance gains exactly, but the K&N sticker will give you at least 75rwhp.  Hope this helps.
Offline Grandmaster
  • 43
« Reply #3 on: December 26, 2004, 03:01:46 AM »
I definitly have more power especially at highway speeds with the K&N and and 2" turbo exhaust.
txzuki07
« Reply #4 on: December 26, 2004, 06:01:15 AM »
Yeah sorry guys I just got home when I posted and forgot to put in the trucks stats
87 suzuki Sammy with  a 1.3 liter with all stock drivetrain and 31-11.50-15 Swampers with 4 inches of lift. Right now it wont get over 55 on the freeway in 4th and wont evan pull 5th I know it will help some but It it worth the money?
Joe
« Last Edit: December 26, 2004, 06:02:34 AM by txzuki07 »
Offline jerryp58
  • 449
« Reply #5 on: December 26, 2004, 06:06:32 AM »
You may notice a little with the exhaust, probably no change with the K&N (that was my experience with my 1.6L, but I still like using a reusable filter), but you may want to Search old posts.  Probably, most would recommend changing gears rather than engine mods.
Jerry
Offline 1bigtracker
  • 3409
« Reply #6 on: December 26, 2004, 07:03:16 AM »
yea with 31's some t-case gears would be a good investment.
stu
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #7 on: December 26, 2004, 07:24:21 AM »
waste of money. long as you got a good clean filter in it, it'll be good.
I am going to get a reusable/washable element for my Tracker eventually, but the K&N system ain't worth it. I just like being able to reuse it, and not throw away, and buy another.
« Reply #8 on: December 26, 2004, 08:04:31 AM »
Like the others I would say do other improvments first!if you have the stock down pipe on your rig that would be the first place that I would look, they are double wall and the inside wall collapses on them and shuts off the exhaust way befor the cat.the next would be to get rid of the vacuum diffuser on the carb for the secondary(little black round thing with a line on each end next to carb) next I would go to a lighter tire, those things are heavy for the street, 4 t0 1 x-fer case gears will help alot or get some 5.12's in the diffs.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #9 on: December 26, 2004, 08:09:47 AM »
I went to replace my air filter and around here the K&N was cheaper than a stock replacement.
So how bad is your air cleaner?
32 MTR's Warn 8000i
txzuki07
« Reply #10 on: December 26, 2004, 12:41:53 PM »
 Ã‚  Thanks for your advice I am in the process of putting the exhaust on. The advise for the gears I've known for a while I've got a set of 4:1 Calmini T-Case gears Just have been wrking too much to get them in. I really need to it hates those big heavy tires especially in the mud and dont try t do any type of crawling. Anyways Thanks for the advise.
Joe
« Last Edit: December 26, 2004, 12:43:04 PM by txzuki07 »
