jeep spacer boring the hole
  • 1493 Views
Offline TrAkLsI
  • 61
« on: April 02, 2007, 08:08:57 PM »
What is the best, fastest way?    thanks,
Offline museboy07
  • 641
Re: jeep spacer boring the hole
« Reply #1 on: April 02, 2007, 08:13:16 PM »
i just bought some also.  the center needs to be bored to 2.5in.  i used a hole saw made for cutting wood.  armor all is the best lubricant to use also.  i found that out after i did mine. i used wd40 which didnt help at all it just melted the plastic spacer...but it still works...gave me almost 2 in of lift  :)
Offline TrAkLsI
  • 61
« Reply #2 on: April 02, 2007, 08:30:52 PM »
 I'll try that.  thanks, museboy07
Offline PHX96TRACK
  • 90
« Reply #3 on: April 04, 2007, 11:46:32 PM »
Museboy is correct, 2-1/2 hole saw works fine for the front. I didn't need to bore the rears I could shove them on. Home depot $6
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
