how to get gas cap off with out key
  • 2230 Views
bryans 86
« on: April 03, 2007, 08:53:04 AM »
so yeah i just bought a samari and there is no key to unlock the gas cap how can i get it off just pry i off and hopefully rebend the lip on the filler neck ?
Offline Utah_Tracker
  • 179
Re: how to get gas cap off with out key
« Reply #1 on: April 03, 2007, 09:16:19 AM »
usually you can just drill the lock mechanizm out. it's easier and less messy.
91 soft top Tracker, 3' Calmini Sup, locker around, Auto, & no Power Steering
GO BIG or GO HOME
« Reply #2 on: April 03, 2007, 09:51:47 AM »
I just drill a hole in the cap (1/8-3/16) just beside the lock and put a small screw in the hole and it will work just like a regular cap.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: April 03, 2007, 11:00:27 AM »
Squeze the cap with chanell lock pliers.
     Kevin
bryans 86
« Reply #4 on: April 03, 2007, 11:28:51 AM »
what i ended up doing was putting a common screw driver in there and just stated poping pices out till i got to the actual piece that just screws in un screwed that and glued it to the top of the gas cap and bam new gas cap works sweet thanks for the ideas
« Reply #5 on: April 03, 2007, 02:32:53 PM »
Cutting torch works. ::)
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« Reply #6 on: April 03, 2007, 02:48:22 PM »
[/quote]
[/quote]
You're kidding I hope!
-Adam
« Last Edit: April 03, 2007, 02:50:39 PM by daddyizzle »
